I'm trying to build a very large Fortran program and getting the message above. I get it with Intel 9 or 10. This program builds fine on CVF. Any idea what this message means?
Pete
Pete
Do you have a .obj which hasn't been rebuilt since CVF? I don't have a working CVF installation to verify whether that library came with CVF; it isn't part of an ifort installation. EPC hasn't been in ifort since before 8.0.
I got past it with /NODEFAULTLIB:libCEPCF90MD
There may have been an issue with out of date object files also.
Pete
Pete
That library has nothing to do with CVF. It comes from Intel Fortran 7.1 or earlier. You would have exactly the same problem building with CVF using the same files, unless you recompiled all of the Fortran sources.
