Dear all,
I just got a new FATAL error after the errorsfor IMSL. Here is it:
x64\Debug/closefile.obj : fatal error LNK1112: module machine type 'x64' conflicts with target machine type 'X86'
I havetried the following methods:
1. project properties-->linker-->advanced taget Machine to Machine X86 (/MACHINE: IX86)
2.I have created a new platform for x64.
3. tools-->intel fortran-->complilers, I seclected x64 as my target platform and Intel fortran compiler 10.1.014 [Intel 64]
So is there anyone can solve this? Thank you all in advance.
lan
Acknowledge know as known, unknow as unknown and that is knowledge.
You need to remove that /MACHINE:IX86. Your friend's suggestion is incorrect and will make things worse.
Try going to the Linker > Advanced property page and make sure that Target Machine is "Not Set".
What you did in step 3 did not select a target platform. What that does is allow you to change the directory lists for the compiler for the different platforms.
To choose the x64 platform, click Build > Configuration Manager. Under Active Solution Platform, select
You have now created an x64 platform and selected it. You can change back by using the platform dropdown at the top of the VS window.
Make sure you added the right IMSL folders to the "Intel 64" version of the compiler in Tools > Options > Intel Fortran > Compilers.
Dear Steve,
x64Debug/closefile.obj : fatal error LNK1112: module machine type 'x64' conflicts with target machine type 'X86'
What I did for the IMSL folers is as follows:
Tools-->Options-->Intel Fortran-->compilers
for Include I added: C:Program Files (x86)VNIimslfnl600Intel64includeDLL
fpr library list I added: C:Program Files (x86)VNIimslfnl600Intel64lib
for the VC window in step 3, I selected the configuration manager and in the Platform colume I select new and build a new project platform x64, and copy settings from Win 32. I guess it is the same as you suggested.
The problem is that I still have the same error.
In that first step, you need to make sure that you selected "Intel 64" as the platform to change.
Check the Linker > Command Line property page to make sure there is no /MACHINE switch there.
Dear all,
I have tried several changes but the error is still there.
1. I have make sure that linker>command line in the additional options I deleted /MACHINE:IX86 there. However, in the all options window, I do notice that there is '/MACHINE:IX86' and it is impossible to change it in that window.
2. My friend also suggested:
Linker->General->Additional library Directories and add one directory C:Program Files(x86)Microsoft Visual Studio 8VClib there.
Is there any other solution?
lan
Please help me to locate the click "Build" command and the way to get into whatever solution you provided above.
Since i'm also getting the same issue "fatal error LNK1112: module machine type 'X86' conflicts with target machine type 'x64' " while running a subroutine in abaqus. My machine is 64bit Windows platform.
Maybe i am new to it ,so please excuse me for my basic doubt.
-nikhil
Hi. I would recommend the steps in the following two articles to make sure you have the Microsoft 64 bit compiler installed and also how to build a 64 bit application. Let us know on this thread if you have problems/questions.
http://software.intel.com/en-us/articles/configuring-microsoft-visual-studio-for-64-bit-applications/
http://software.intel.com/en-us/articles/building-intel-64-architecture-applications-in-microsoft-visual-studio/
Wendy
Thanks Wendy for your response,
I was able to fix that error but now i'm getting another error:
"standardU.lib : fatal error LNK1120: 2 unresolved externals"
Also i would like to tell you that I have a Intel frotran 32 bit complier in my machine , so is it that we need 64 bit only.
Nikhil
I am not sure what might be causing that error message. If you have a test case you can post it here and I can take a look at it.
Wendy
