29650 Discussions
LNK2005 Error for Internal Subprograms
pjh_gn
I have a LNK2005 error complaining about 2 internal subprograms (in different modules) with the same name. The linker sees 2 copies of the (decorated) object name 'subprogram name':BLK_debug_param_const.
The Debugging/Information for Parameter Constants setting is on "All" and the linker error goes away when I set it to "None" or "Used in Program". Is this a known issue? I tried to reproduce with a simpler program but couldn't, sorry.
That's not an issue I'm familiar with. If you're seeing this in the 9.1.029 compiler, please send a test case (even a big one if necessary) to Intel Premier Support.
