imsl in fortran 9.1 for windows
juan_rubio-ramirez
Hi
i was using fortran compaq and i am migrating to intel 9.1 with visual studio 8.0.
i am trying to compile my code...and i have problems with linking the imsl libraries....basically i have messages like unresolved external symbol.
i got the professional version of intel 9.1. the problem is that i am not sure if my IT installed the imsl libraries? is there any way to check?
i cannot find the typical folder c:...vnictt6.0libia32
instead there is a folder called c:program filesmicrosoft visual studiodf98imsllib
are the libraries there? thanks
If that folder isn't there, then IMSL isn't installed. No, you cannot use the IMSL libraries from CVF, which is what you found under df98.
As a last check, you can do Start..All Programs and see if a "Visual Numerics" entry appears there with "IMSL 5.0 for Intel Fortran..." entries underneath.
juan_rubio-ramirez
i found the libraries..i think. they are at c:program files (x86)vnictt6.0libem64t
but if i try to compile a 64 bit code calling this lib...i get
fatal error lnk1112: module machine type 'x64' conflicts with target machine type 'x86'
It sounds as if you're using the IA-32 compiler, then. If you want to build a 64-bit application, you need to create and select an "x64" configuration in Visual Studio. See the Building Applications manual for details.
