Tony,
I too have seen this behavior and turned in an issue on it ( Issue #231637 ).
Briefly, I am responsible for CVF application that is comprised of 94 projects all within the same workspace. 41 are programs, 53 are libraries that the projects link against.
Have had it this way in CVF since November 2000.
I started evaluation of IVF 8 and after converting approx. 1/3 of the .vcproj to .vfproj, I received a low virtual memory warning. First time it has ever happened. At the time I had a single 655 MB pagefile. Installed a secondary pagefile of 655 MB and was finally able to get thru the conversion.
Takes approx. 3 min just to bring up the new solution. Can't do much else either while it is bringing it up. Takes approx. 3 min 30 sec just to close it.
My VM Size according to Task Manager after bringing up the solution is > 1 GB.
Please submit an issue. The more that verify this as a problem, the more likely we will see a resolution.
Steve:
Impractical to expect someone to supply a solution to recreate this. Mine is > 120MB zipped ( Premier support limits uploaded files to 10MB ). Not to mention the sensitive nature of the source ( an application that is sold and/or leased ) that the people I work for would not want to get loose.
Steven Starkey
I'm glad to see I'm not the only one to use the studio in this way.
Some times I think i've got the wrong end of the stick on how to use the studio for multi-program / multi-project software suites.
I'm not sure how many people have upgraded CVF to Intel, but there can not be many serious users as there are many conversion bugs still kicking around with projects and dependancies (all the other ones are reported)
Tony
Steve.
Extracting fortran fromONE of my projects increases the virtual memory by 80 MB.
Perhaps something is very wrong somewhere.
I have sent a copy to premier support (look under 233327 if you want to see the dsp)
Tony
Steve,
Can you quickly check the project I have attached. I need to see if the Virtual memory problem is to do with my machine (premier have gone quiet on it)
Tony
Steve
Tony
