29429 Discussions
Latest compiler is always selected, regardless of sourced path
John4
Valued Contributor I
I have ifort versions 211.0.084 and 2011.1.107 installed. Since the latest seems to reintroduce the error message "The INTERFACE/CONTAINS stack is full" (a false positive, for which I still don't have a small test), I tried to change the source line in .bashrc file to point to the previous version (just like I used to do with ifort versions < 12):
[bash]. /opt/intel/composerxe-2011.0.084/bin/ifortvars.sh intel64[/bash]
But with that line, version 2011.1.107 is selected instead. The problem lies in the fact that the variable PROD_DIR in both versions of ifortvars.sh point to "/opt/intel/composerxe-2011", effectively making any previous installation useless... Was that the intended behavior?
No, that's not intended and our install team has already been asked to correct this.
We'll take a larger test case if you can't reduce the problem. Probably best to submit it through Intel Premier Support.
