29382 Discussions
Leaking memory from derived-type array in fortran
Ahmad_S_
I am using derived-type array in fortran. I ran the executable through valgrind and realized that I am leaking memory. After poking around, I realized that the leaking is related to a compiler flag '-qopenmp'. If this flag is used with intel15, valgrind detects memory leak.
Here is the relevant part of valgrind report when I use intel15 with '-qopenmp' flag:
==84663== 12 bytes in 2 blocks are indirectly lost in loss record 1 of 3
==84663==    at 0x4C26B0D: malloc (vg_replace_malloc.c:296)
==84663==    by 0x40BE9F: for_alloc_allocatable (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==84663==    by 0x402CDD: classdynamicintegerarray2d_mp_allocate_dynamicintegerarray2d_ (ClassDynamicIntegerArray2d.f90:173)
==84663==    by 0x40329F: allocatewithintent_ (allocateWithIntent.f90:97)
==84663==    by 0x4034E2: MAIN__ (main.f90:82)
==84663==    by 0x40299D: main (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==84663==
==84663== 32 bytes in 1 blocks are still reachable in loss record 2 of 3
==84663==    at 0x4C28884: calloc (vg_replace_malloc.c:623)
==84663==    by 0x5BB930F: _dlerror_run (dlerror.c:142)
==84663==    by 0x5BB9079: dlsym (dlsym.c:71)
==84663==    by 0x41809E: for__aio_init (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==84663==    by 0x405FCE: for_rtl_init_ (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==84663==    by 0x402998: main (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==84663==
==84663== 156 (144 direct, 12 indirect) bytes in 1 blocks are definitely lost in loss record 3 of 3
==84663==    by 0x402B40: classdynamicintegerarray2d_mp_allocate_dynamicintegerarray2d_ (ClassDynamicIntegerArray2d.f90:172)
==84663==
==84663== LEAK SUMMARY:
==84663==    definitely lost: 144 bytes in 1 blocks
==84663==    indirectly lost: 12 bytes in 2 blocks
==84663==      possibly lost: 0 bytes in 0 blocks
==84663==    still reachable: 32 bytes in 1 blocks
==84663==         suppressed: 0 bytes in 0 blocks
However if I use intel 17, valgrind detects possible memory leak if I don't use this flag. Here is the relevant part of valgrind report when I use intel17 without '-qopenmp' flag:
==85454== 92 bytes in 2 blocks are possibly lost in loss record 2 of 3
==85454==    at 0x4C26B0D: malloc (vg_replace_malloc.c:296)
==85454==    by 0x4695FB: _mm_malloc (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==85454==    by 0x409A75: for_allocate (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==85454==    by 0x403382: classdynamicintegerarray2d_mp_allocate_dynamicintegerarray2d_ (ClassDynamicIntegerArray2d.f90:173)
==85454==    by 0x403A05: allocatewithintent_ (allocateWithIntent.f90:97)
==85454==    by 0x403BC4: MAIN__ (main.f90:82)
==85454==    by 0x402F8D: main (in /work-zfs/sghosh20/shahba/PaperPhaseField/notFinalized/polycrystalline/testLeak/a.out)
==85454==
==85454== 184 bytes in 1 blocks are possibly lost in loss record 3 of 3
==85454==    by 0x40312D: classdynamicintegerarray2d_mp_allocate_dynamicintegerarray2d_ (ClassDynamicIntegerArray2d.f90:172)
==85454==
==85454== LEAK SUMMARY:
==85454==    definitely lost: 0 bytes in 0 blocks
==85454==    indirectly lost: 0 bytes in 0 blocks
==85454==      possibly lost: 276 bytes in 3 blocks
==85454==    still reachable: 32 bytes in 1 blocks
==85454==         suppressed: 0 bytes in 0 blocks
I am attaching a simple code that mimics this error. To compile the code, please run the compile.sh script.
Ahmad_S_
There seems to be no leak, after all. I realized if I deallocate the derived-type arrays at the end of the program, valgrind reports no memory leak , no matter which compiler is used or whether '-qopenmp' is used or not.
