Left align numbers
mohanmuthu
Need to print two column of numbers (integers) with same width, with 1st column left aligned and 2nd column right aligned. Can someone help me?
nvaneck
Or, Write (outputfile,'(I0,T10,I10) n1,n2
Les_Neilson
Valued Contributor II
Something like :
character(widthRequired) leftString
integer firstNumber
integer secondNumber
write(leftString, *) firstNumber
leftString = adjustl(leftString)
write(outputfile,fmt) leftString, secondNumber
where fmt is say (A10, I10) and "10" is the widthRequired.
Hope this helps but you should look up ADJUSTL (and maybe ADJUSTR) in the help
Les
mohanmuthu
Thank you Les!
I was trying out only with numbers and the string conversion worked for me.
nvaneck
Les_Neilson
nvaneck wrote:
Or,
I had totally forgotten about format i0  I spend most of my life in C# now. Punishment but I don't know what I did wrong. :-)
mohanmuthu
nvaneck wrote:
Or,
Most simplest form. Thank you!
