29235 Discussions
Library for multi-variate lognormal distribution
sdahl
Does anyone know where there is a Fortran library that will generate multi-variate lognormal distribution from inputs of mean, std dev and covariances?
durisinm
You can try looking in IMSL from VNI (came with CVF Pro and will come with IVF Pro), CVF's CMXL library, Intel's math library (don't know the name), and NAG's routine library.
Mike D.
Jugoslav_Dujic
Valued Contributor II
...or, before all, www.netlib.org
Jugoslav
sdahl
Thanks,I found routines to generate multivariate normal in both suggestions. If one knows the transformation from the lognormal inputs to the normal inputs, these routines can be used. I also found this transformation, and it appears to be working!
