29650 Discussions
License/purchasing question (Compiler Suite Pro Linux).
Henrik_S_
I am trouble finding the Intel Compiler Suite Pro boxed/complete edition of the software. I can find license only, but not the boxed edition. I can find C++ and Fortran boxed separately. If I purchase a license only, can I download the complete version of the software?
- Henrik
Ron_Green
Henrik,
Yes, if you buy the license-only product, you will be able to download all the compilers and tools that come with the Intel Compiler Suite Pro.
What you get with your purchase is a "serial number". This will come via email to you. It will be an alpha-numeric string similar to 'ABCD-123EFG45'. You then go to
https://registrationcenter.intel.com
and you create a username and password using your email for username. And you register that serial number. When you login to Registrationcenter, you will see all the products in the Compiler Suite Pro for download.
Also, if you wish, you also will have the ability to select older versions of any of the products to download.
You will want to check back on Registrationcenter for updates. We post updates to the compilers and tools to Registrationcenter. For one year after your purchase you will get ALL versions of the tools that come out.
After 1 year, you purchase a Service & Support Renewal (SSR). This is at a reduced rate from the normal product. This SSR is also a serial that is registered. This keeps your account active and all new products will continue to be available to you.
If you do not purchase the SSR, you will still see the products available at the time your 1 year support ended, but you will not be able to download newer products.
Let me know if you have questions.
ron
