29487 Discussions
Pragma for Zi option with fortran 10
atu
I have a code that is compil with /Zi option. When this option is set the compiler crash
I want to disable this option for only one source with a #pragma directive.
Which pragma directive I have to use for this ?
There is no pragma/directive for this. You can set the options for an individual source in a project by right clicking on the file and selecting Properties. Rather than using /Zi, you should be using the Debug property page.
If you are using a current compiler and are seeing the compiler "crash", please report this to Intel Premier Support, or if the source is reasonably small, attach it to a reply here (use the Options tab when posting.)
