License usage
Matthew_Mawhinney
we need a compiler to compile fortran user subroutines that will be used in Abaqus. The abaqusjob calls the user subroutinesthat the user specifies and during the job runtime, the compiler is called and compiles the user subroutine. Is it correct to assume that the compiler license will only be in use during the compiling process, even if the parent Abaqus job that called the subroutine runs much longer after the compiling finishes?
Yes, that is correct.
Matthew_Mawhinney
thanks steve for the quick reply
