- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
astap.for(62650): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [IFPORT]
use ifport
I'm compiling in the build environment so all the environment variables have been set correctly and IFPORT.MOD is in the right include directory. So the include path would appear to be correct. Is this error message wrong? Why doesn't it find the compiler provided library?
dave
- Etiquetas:
- Intel® Fortran Compiler
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
It is possible that you have more than one version of the compiler installed, and the compiler version that you ran is trying to read a module file (*.mod) that was compiled with a different version of the compiler.
The linker does not have any interest in .mod files. Likewise, the compiler does not read library files.
I also note that the source file is quite large. Is it possible that some compiler/computer limits are being bumped into?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
c:\V53Ivf64\sinda33\HumeTime\vivf.inp_sw>ifort @infon.lnk
Intel Visual Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100414 Package ID: w_cprof_p_11.1.065
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
ifort astap.for /fpe:0 /real_size:64 /integer_size:64 /names:lowercase /iface:cref /module:C:\PROGRA~1\CULLIM~1\SINDAF~3\mod /MD /iface:mixed_str_len_arg /include:C:\PROGRA~1\CULLI
M~1\SINDAF~3\lib /assume:byterecl /extend_source:132 /O3 /traceback /INCREMENTAL:NO
use ifport
compilation aborted for astap.for (code 1)
The source isn't that large compared to most of our files so it isn't likely to be hitting limits. It appears to be a compiler message, but says to check include paths. It knows it is looking for a module, so does it really check INCLUDE paths? Or does it only follow MODULE inputs? The line is simply calling a function from the IFPORT module. Do we need to do more than just USE the module name? I don't find anything in the documentation that helps define how to use it more than inserting the USE statement.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
If you can't use the command window provided, at least invoke the ifortvars.bat file to set all environment variables needed to run the compiler. You can find that bat file in Program Files (x86)\Intel\Compiler\11.1\064\bin and you should use
ifortvars intel64
To answer your question about INCLUDE:
Yes, the compiler searches the INCLUDE directories to find modules. The /module switch is appended to the set of INCLUDE directories, but does not limit the search to that directory. It also names the directory where any .mod files generated by this compilation should be put.
ifortvars.bat sets the INCLUDE environment variable, including the directory where ifport.mod resides.
You should not have to do anything other than USE the module name. Well, once the INCLUDE environment variable is set up correctly of course.
I hope this helps,
-- Lorri
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I did use the "Fortran Build Environment" menu item from the Intel list. So all of that should have been set correctly. Here is the environment from the command prompt window. It has the INCLUDE path set. I verified that the file IFPORT.MOD exists within the paths in the INCLUDE set.
Maybe this will help you figure out why it doesn't work for me.
Can you tell me what to do next since I already think this should work okay without getting errors.
Dave
ALLUSERSPROFILE=C:\ProgramData
ANS_OLD_ATTACH=1
APPDATA=C:\Users\dajum\AppData\Roaming
CLASSPATH=.;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
CM2012DIR=C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
CommonProgramFiles=C:\Program Files (x86)\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=DAJUM-PC
ComSpec=C:\Windows\system32\cmd.exe
CPATH=C:\Program Files (x86)\Intel\Compiler\11.1\065\mkl\include;
FPATH=C:\Program Files (x86)\Intel\Compiler\11.1\065\mkl\include;
FP_NO_HOST_CHECK=NO
Framework35Version=v3.5
FrameworkDir=C:\Windows\Microsoft.NET\Framework64
FrameworkVersion=v2.0.50727
F_EM64T_REDIST11=C:\Program Files (x86)\Common Files\Intel\Shared Files\fortran\
HOMEDRIVE=C:
HOMEPATH=\Users\dajum
IFORT_COMPILER11=C:\Program Files (x86)\Intel\Compiler\11.1\065
ILBDIR=C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
INCLUDE=C:\Program Files (x86)\Intel\Compiler\11.1\065\mkl\include;C:\Program Files (x86)\Intel\Compiler\11.1\065\Include;C:\Program Files (x86)\Intel\Compiler\11.1\065\Include\Int
el64;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\ATLMFC\INCLUDE;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\INCLUDE;C:\Program Files\Microsoft SDKs\Windows\v6.0
A\include;
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\Intel\Licenses;C:\Program Files (x86)\Common Files\Intel\Licenses
LIB=C:\Program Files (x86)\Intel\Compiler\11.1\065\mkl\em64t\lib;C:\Program Files (x86)\Intel\Compiler\11.1\065\Lib\intel64;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\AT
LMFC\LIB\amd64;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\LIB\amd64;C:\Program Files\Microsoft SDKs\Windows\v6.0A\lib\x64;
LIBPATH=C:\Windows\Microsoft.NET\Framework64\v3.5;C:\Windows\Microsoft.NET\Framework64\v2.0.50727;C:\Windows\Microsoft.NET\Framework64\v3.5;C:\Windows\Microsoft.NET\Framework64\v2.
0.50727;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\ATLMFC\LIB\amd64;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\LIB\amd64;
LIBRARY_PATH=C:\Program Files (x86)\Intel\Compiler\11.1\065\mkl\em64t\lib;
LOCALAPPDATA=C:\Users\dajum\AppData\Local
LOGONSERVER=\\DAJUM-PC
NUMBER_OF_PROCESSORS=8
OS=Windows_NT
Path=C:\Program Files (x86)\Intel\Compiler\11.1\065\mkl\em64t\bin;C:\Program Files (x86)\Intel\Compiler\11.1\065\Bin\intel64;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\B
IN\amd64;C:\Windows\Microsoft.NET\Framework64\v3.5;C:\Windows\Microsoft.NET\Framework64\v3.5\Microsoft .NET Framework 3.5 (Pre-Release Version);C:\Windows\Microsoft.NET\Framework64
\v2.0.50727;C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\VCPackages;C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE;C:\Program Files (x86)\Microsoft Visual
Studio 9.0\Common7\Tools;C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\Tools\bin;C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin\x64;C:\Program Files\Microsoft SDKs\
Windows\v6.0A\bin\win64\x64;C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin;C:\Program Files (x86)\Common Files\Intel\Shared Files\fortran\bin\Intel64;C:\Windows\system32;C:\Wind
ows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Dell\Dell Wireless WLAN Card;C:\Program Files (x86)\NTRU Cryptosystems\NTRU TCG Software S
tack\bin\;C:\Program Files\NTRU Cryptosystems\NTRU TCG Software Stack\bin\;C:\Program Files\Wave Systems Corp\Gemalto\Access Client\v5\;C:\Program Files (x86)\Common Files\Roxio Sh
ared\DLLShared\;C:\Program Files (x86)\Common Files\Roxio Shared\10.0\DLLShared\;c:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn\;c:\lf9557;c:\bin;C:\Program Files (x86)\
QuickTime\QTSystem\;C:\Program Files (x86)\InstallAware\InstallAware 10;C:\Program Files (x86)\IDM Computer Solutions\UltraEdit\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_ARCHITEW6432=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 30 Stepping 5, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=1e05
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
QTJAVA=C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
RoxioCentral=C:\Program Files (x86)\Common Files\Roxio Shared\10.0\Roxio Central36\
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\dajum\AppData\Local\Temp
TMP=C:\Users\dajum\AppData\Local\Temp
USERDOMAIN=dajum-PC
USERNAME=dajum
USERPROFILE=C:\Users\dajum
VCINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC
VS90COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\Tools\
VSINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio 9.0
windir=C:\Windows
WindowsSdkDir=C:\Program Files\Microsoft SDKs\Windows\v6.0A\
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
If you forced the compiler to use a specific .mod file (ifort *.f90 ifport.mod) it should tell you if there is a match.
The source code ifport.f90 is provided, so you can make your own ifport.mod.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Dave
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
ifort astap.for /#x /fpe:0 /real_size:64 /integer_size:64 /names:lowercase /iface:cref /module:C:\PROGRA~1\CULLIM~1\SINDAF~3\mod /MD /iface:mixed_str_len_arg /include:C:\PROGRA~1\C
ULLIM~1\SINDAF~3\lib /assume:byterecl /extend_source:132 /O3 /traceback /INCREMENTAL:NO
C:\PROGRA~2\Intel\Compiler\11.1\065\bin\intel64\fortcom \
-D__INTEL_COMPILER=1110 \
-D_MT \
-D_DLL \
-D_M_AMD64 \
-D_M_X64 \
-D_WIN64 \
-D_WIN32 \
-D__INTEL_COMPILER_BUILD_DATE=20100414 \
-mGLOB_pack_sort_init_list \
-I. \
-IC:\PROGRA~1\CULLIM~1\SINDAF~3\lib \
-INCREMENTAL:NO \
-IC:\PROGRA~2\Intel\Compiler\11.1\065\include\intel64 \
"-IC:\Program Files (x86)\Intel\Compiler\11.1\065\mkl\include" \
"-IC:\Program Files (x86)\Intel\Compiler\11.1\065\Include" \
"-IC:\Program Files (x86)\Intel\Compiler\11.1\065\Include\Intel64" \
"-IC:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\ATLMFC\INCLUDE" \
"-IC:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\INCLUDE" \
"-IC:\Program Files\Microsoft SDKs\Windows\v6.0A\include" \
"-assume byterecl" \
"-extend_source 132" \
-fpe0 \
"-fp_modspec fp_speculation_STRICT" \
"-iface cref" \
"-iface mixed_str_len_arg" \
"-integer_size 64" \
"-module C:\PROGRA~1\CULLIM~1\SINDAF~3\mod" \
"-names lowercase" \
-O3 \
"-real_size 64" \
"-reentrancy threaded" \
-traceback \
-mP1OPT_version=11.1-intel64 \
-mGLOB_diag_file=astap.diag \
-mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \
-mGLOB_tune_for_fort \
-mGLOB_use_fort_dope_vector \
-mP2OPT_static_promotion \
-mP1OPT_print_version=FALSE \
-mP3OPT_use_mspp_call_convention \
"-mGLOB_options_string=-#x -fpe:0 -real_size:64 -integer_size:64 -names:lowercase -iface:cref -module:C:\PROGRA~1\CULLIM~1\SINDAF~3\mod -MD -iface:mixed_str_len_arg -include:C:
\PROGRA~1\CULLIM~1\SINDAF~3\lib -assume:byterecl -extend_source:132 -O3 -traceback -INCREMENTAL:NO" \
-mGLOB_cxx_limited_range=FALSE \
-mGLOB_traceback \
-mP3OPT_defaultlibs_omit=FALSE \
-mP3OPT_defaultlibs=P3OPT_DEFAULTLIBS_DYNAMIC_MULTITHREAD \
-mP3OPT_defaultlibs_select=P3OPT_DEFAULTLIBS_SELECT_F90_IVF \
-mP3OPT_defaultlibs_f90_port \
-mP1OPT_check_stack \
-mP3OPT_inline_alloca \
-mGLOB_routine_pointer_size_64 \
-mGLOB_split_functions=0 \
-mIPOPT_activate \
-mIPOPT_lite \
-mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 \
-mGLOB_use_base_pointer \
-mGLOB_fp_speculation=GLOB_FP_SPECULATION_STRICT \
-mGLOB_extended_instructions=0x8 \
-mP2OPT_gen_read_only_strings=TRUE \
-mP2OPT_subs_out_of_bound=FALSE \
-mGLOB_ansi_alias \
-mIPOPT_args_in_regs=0 \
-mPGOPTI_value_profile_use=T \
-mGLOB_opt_level=3 \
-mP2OPT_hlo_level=3 \
-mP2OPT_hlo \
-mIPOPT_obj_output_file_name=astap.obj \
-mGLOB_os_target=GLOB_OS_TARGET_WINNT \
-mP3OPT_asm_target=P3OPT_ASM_TARGET_MASM5 \
-mP3OPT_obj_target=P3OPT_OBJ_TARGET_NTCOFF \
-mGLOB_obj_output_file=astap.obj \
-mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \
-mP1OPT_source_file_name=astap.for \
astap.for
use ifport
del C:\Users\dajum\AppData\Local\Temp\42962arg
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Dave
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I use a bunch of our own modules which are on the /MODULE path. Those get found fine.
Adding USE KERNEL32
astap.for(5): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [KERNEL32]
USE KERNEL32
astap.for(62651): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [IFPORT]
use ifport
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
In your ifon.lnk file, do you have the switch -INCREMENTAL:NO
Please change that to look like /link /INCREMENTAL:NO
The "parsing rule", if you will, for include directories is that anything after a capital I is considered the rest of the directory. Unless the switch is a known-compiler switch. INCREMENTAL:NO is a linker switch.
The compiler believes that you have a directory called NCREMENTAL:NO and it's trying tosearch it for ifport.mod
When the error is returned (because that is clearly an invalid directory spec) the compiler says "File not found".
-- Lorri
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Thanks Lorri
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
