Link error using makefile
John_S_
This is a simple test for ifort.
test.90:
integer a,b,c
a = 1
b = 2
call sub(a,b,c)
write(*,*)'c=',c
stop
end
sub.f90:
subroutine sub(a,b,c)
integer a,b,c
c=a+b
return
end
The makefile is:
lib     = sub.lib
exe     = test.exe
$(lib):
    ifort /c sub.f90
        lib /out:$(lib) sub.obj
$(exe):
        ifort test.f90 sub.lib
clean:
 -del *.exe *.obj
I first make the library with the command
make sub.lib
Then I try to make the exe with the command
make test.exe
This gives an error on linking - LNK1104: Cannot open file ifconsol.lib.
However, if I give the command
at the command prompt, the program is made without error.
Why is the makefile causing this error?
Thank you.
Kevin_D_Intel
Change all uses of "lib" in your makefile to some other spelling (e.g. mylib). As is, the name interferes with the LIB environment variable and throws off the linker. Another way to see the interference is to run nmake with the /E option; however, /E is not the solution though, renaming 'lib' is.
IanH
Your makefile obliterates the LIB environment variable that the linker uses for the library search path.
Rename the `lib` variable in your makefile to something else.
John_S_
Thank you Kevin and Ian. It is now working.
