Link invalid option issue
Thomas_Folegot
I've been trying to install a Fortran code. This code is supposed to be compatible with Interl Fortran, but the Makefiles are wrtitten for MacOS, whereas I'm trying to compile on Windows XP. I'm running Visual Fortran Compiler 11.1.051 launched from the Cygwin window.
I already compiled the library into the directory D:/users/misc/
Now, I've been trying to compile codes into the D:/users/global directory. The original Makefile uses the -L and -l options: -L../misc and -lmisc that I converted for Windows by adding the D:/users/misc path into the environment variable LIB.
The command is the following:
toasc.exe: toasc.f90
ifort /O3 /nologo /Ob2 /assume:byterecl /threads /heap-arrays /include:D:/users/misc /Qparallel /exe:tasc.exe toasc.f90
The compiler produce the toasc.obj without complaining but replies the following error:
Link invalid option --o.
Thanks in advance for your help.
TimP
Quoting - Thomas Folegot
This looks as if a link.exe other than Microsoft's appears on your PATH. If so, specifying /Qlocation should work:
$ cat ia32/ifort.cfg
# This Configuration file may be used for additional switches
-Qlocation,link,"C:Program FilesMicrosoft Visual Studio 9.0VCbin"
-assume:minus0,protect_parens,buffered_io,byterecl
-Qprec-div -Qprec-sqrt
For intel64ifort.cfg, use the AMD64bin.
Thomas_Folegot
Quoting - tim18
Thanks Tim for your help.
Now I have an error1 ...
What is the equivalent of -L on Windows ?
Thomas_Folegot
Its works now, no pb.
Thanks again for your help.
Thomas.
