29280 Discussions
Linker error ifort: error: could not find 'Bin'
as_senthil
Hi All,
I installed licensed "Intel Visual Fortran Compiler 9.0 for Windows". If i compile the program it creates the .OBJ file only and it shows the error
Environment variables are set correctly. I am not installed visual studio .net, I am compiling the fortran program in command line only.....
Pls tell me how to solve this problem
TimP
You must have some version of Microsoft C, for example, Visual C++ 2003 Toolkit for 32-bit ifort. For those versions which aren't supported with automatic installation, you must edit the installed ifortvars.bat and ifort.cfg files, to incorporate the corresponding paths to your C installation. 2003 Toolkit installation has been covered several times previously in this forum. The message you quote appears to come from ifort.cfg, which requires the path to the folder where Microsoft LINK is installed, e.g.
-Qlocation,link,"c:program filesMicrosoft Visual C++ toolkit 2003Bin"
as_senthil
Thanks......
But in my system I installed Microsoft visual studio 6.0
so how to fix this error
as_senthil
I edited the ifort.cfg as follows
# Path to Microsoft Visual C++* .NET 8.0 linker
-Qlocation,link,"D:AppsMicrosof tvisual studiovc98Bin"
-Qoption,link,/nodefaultlib:uuid.lib
and in the ifortvars.bat file
@call "D:appsmicrosoft visual studiovc98BinVcvars32.bat"
But it gives the error
ifort: error: unable to run 'D:AppsMicrosof tvisual studiovc98Bin'
how to solve this
First, use of Visual Studio 98 is not supported. It may work for some applications.
Second, if you have accurately reported the error message, you have incorrectly specified the path.
Lorri_M_Intel
First - let me second what Steve said; it is unsupported to run Intel Visual Fortran with Microsoft Visual C V6.0. If your program works, good. If it doesn't, we can't help you.
That said --- I noticed a typo in your reply. Is this same typo actually in your .cfg file?
^^^ note where the space is
- Lorri
