I have a VC6 C++ dll which exports several methods which i would like to link from Intel Fortran, the C code is about :
__declspec(dllexport) int WINAPI FGETS(int &a)
int b = a;
// do something here
return(b);
the def file removes the decoration by using Alias :
EXPORTS
_FGETS = _FGETS@4
and I call the method from Fortran as
external FGETS
integer i, j
i = 5
j = FGETS(i)
j = FGETS(i)
the linker works correctly (producing the executable) and when I debug the program it appears that Fortran correctly calls GETS by passing (first call) the correct value of i (5) , unfortunately I saw that the memory address of i (as passed to the C method) was :
0x0012FF74 (first call)
0x0012FF78 (second call)
0x0012FF7c (third call)
the C method receives the correct value only on first call, on subsequent calls the values were uncorrect.
I did presume that the address of i shouldn't change and I am not able to figure out why, any suggestions ?
Roberto
int b = a;
return(b);
EXPORTS
_FGETS = _FGETS@4
external FGETS
integer i, j
i = 5
j = FGETS(i)
j = FGETS(i)
Roberto
You have calling conventions mismatch (and that's probably the root cause). WINAPI means __stdcall, but the default for Intel Fortran is __cdecl. Since stdcall and cdecl routines clean stack differently, you have a "fandango on stack" case (cause of many tough-to-catch bugs).
Your linking succeeded because you cheated -- basically, you renamed the export to match the C calling convention, but the stack is still screwed. By renaming, you removed the symptoms of LNK2001, but not the cause.
So, either remove WINAPI attribute and .def file on C++ side, or specify a correct interface on Fortran side, i.e. instead of external FGETS write:
P.S. cdecl-style renaming will still cause confusion with eventual maintainers/users of the code ;-).
interface integer function FGETS(a) !dec$attributes stdcall, alias: "_FGETS": FGETS integer:: a end function end interfaceJugoslav
thanks for the suggestion, I am going to test the std. C call (_cdecl), unfortunately we have different Fortran compilers and it seems difficult to find out a solution working on different platforms,
Roberto
Roberto
