Linking errors
andrea_scarabello
Hi there,
I am linking a fortran code written using a compaq compiler and now I am switching to Intel Visual Fortran. When compiling I get fatal errors:
Fatal error cannot open "dformt.lib"
Fatal error cannot open "dfor.lib"
Does anyone have an idea how I could solve the problem? I just started to be familiar with Fortran so I am not a master in it...
Thanks for help,
Cheers
Andrea
Jugoslav_Dujic
Valued Contributor II
Have you tried "rebuild all"? That should fix it.
CVF inserted references to its own run-time libraries into .obj files, but IVF can't find them if the .obj files weren't built with IVF.
If you have some "external" .obj or .lib files within your project, you should rebuild them first also.
Jugoslav
