linux fortran dialog box
ekeom
I would like to program a dialog box using linux fortan complier. The equivalent visual program look like tihs :
use dfwin
use dfwinty ! loads parameter definitions
! for MB_YESNOCANCEL, IDYES etc.
integer hWnd ! hWnd Can be NULL
integer iret
character*100 lpszMessage, lpszHeader
if( i.gt.0) then
lpszMessage = "(I>0), Do You want to continue"C
lpszHeader = "ERROR MESSAGE"C
! If hWnd is null, the message box has no owner window...
iret = MessageBox (hWnd, &
lpszMessage, &
lpszHeader, &
IOR(MB_SYSTEMMODAL, &
IOR(MB_YESNOCANCEL)) )
endif
if(iret.eq.IDCANCEL) then
else if(iret.eq.IDYES) then
else if (iret.eq.IDNO) then
endif
dfwin and dfwinty run visual objects and don't run under Linux.
Thank You very much for Your help.
Didace
You will have to use some separate library to do this. One that supports both Linux and Windows is GINOMENU.
ekeom
I have already use Visual Fortran Library for the Windows version. Thus, I can use separate library for Windows and Linux. The most important is than I want something simple. I just want display some warning, and ask the user to clic on Ok. To be sure that I have read the display message.
Didace
