Linking problem
brian_schick
I have looked through the other posts, and have been unable to find an answer to my problem. Here is the error:
1>Linking...
1>libifcoremt.lib(libifcoremain.obj) : error LNK2019: unresolved external symbol _MAIN__ referenced in function _main
1>Debug/Hostsim.exe : fatal error LNK1120: 1 unresolved externals
I don't think I changed anything in the properties that would cause this.
I am using VS 2005 and ...
Intel Fortran Compiler for 32-bit applications, Version 9.1 Build 20060816Z Package ID: W_FC_C_9.1.029
Brian
I have seen this if you create a Console application that does not contain a Fortran main program. I've also seen it when the project has inconsistent library settings or has added libraries explicitly to the linker options.
brian_schick
Yes, there is no main in this project...I will try to see what to do (I have to talk with the higherups)...Is there any solution the involves not making a Fortran main program?
-Thanks,
Brian
Recreate the project as what it should be - static library or DLL.
brian_schick
You were right...I was missing a file that wasn't given to me that had the main program in it.
Thanks a bunch,
Brian
