29285 Discussions
Linking to MKL DLLs : Unresolved symbols
blamm
I'm trying to link to the DLL versions of MKL when building my exe. My exe also uses pardiso, so I statically link to mkl_solver.lib, and, per the techinical user notes, I also statically link to mkl_c.lib since mkl_solver.lib references symbols defined in mkl_c.lib. So, currently I'm stuck having to use static linking to mkl_solver.lib since there is no DLL library for using pardiso.
I also, and this is the problem, want to use the DLL versions of BLAS found in MKL 7.0.1 (w_mkl_u_7.0.1.007).
So I put the additional dependency of mkl_c_dll.lib in Project|Properties|Linker|Input..Additional Dependencies. I have the Fortran|External Procedures..Calling Convention set to default (when I set it to C, REFERENCE then I get unresolved symbol _pardiso in a procedure that does not even directly or indirectly reference pardiso!).
I have defined in my source (single file) the DLLIMPORT property of the required BLAS procedures thus
MODULE mod_BLAS_real_int
PUBLIC
! import BLAS through Intel MKL DLLs in mkl_c_dll.lib ( IVF-specific )
INTERFACE
REAL(KIND(1.0D0)) PURE FUNCTION DDOT ( n, dx, incx, dy, incy )
!DEC$ ATTRIBUTES DLLIMPORT :: DDOT
REAL(KIND(1.0D0)), INTENT(IN) :: dx(*), dy(*)
INTEGER, INTENT(IN) :: incx, incy, n
END FUNCTION DDOT
SUBROUTINE DGEMV ( TRANS, M, N, ALPHA, A, LDA, X, INCX, &
BETA, Y, INCY )
!DEC$ ATTRIBUTES DLLIMPORT :: DGEMV
REAL(KIND(1.0D0)), INTENT(IN) :: ALPHA, BETA
INTEGER, INTENT(IN) :: INCX, INCY, LDA, M, N
CHARACTER(1), INTENT(IN) :: TRANS
REAL(KIND(1.0D0)), INTENT(IN) :: A( LDA, * ), X( * )
REAL(KIND(1.0D0)), INTENT(INOUT) :: Y( * )
END SUBROUTINE DGEMV
REAL(KIND(1.0D0)) PURE FUNCTION DNRM2 ( N, X, INCX )
!DEC$ ATTRIBUTES DLLIMPORT :: DNRM2
INTEGER, INTENT(IN) :: INCX, N
REAL(KIND(1.0D0)), INTENT(IN) :: X( * )
END FUNCTION DNRM2
REAL(KIND(1.0)) PURE FUNCTION SNRM2 ( n, x, incx )
!DEC$ ATTRIBUTES DLLIMPORT :: SNRM2
REAL(KIND(1.0)), INTENT(IN) :: x(*)
INTEGER, INTENT(IN) :: n, incx
END FUNCTION SNRM2
END INTERFACE
END MODULE mod_BLAS_real_int
The compile builds fine, but I get the following linker errors:
Linking...
Link /OUT:"Release/LoTekFEA.exe" /INCREMENTAL:NO /LIBPATH:"F:Program FilesIntelMKL701ia32lib" /SUBSYSTEM:CONSOLE mkl_c_dll.lib Release/LoTekFEAfa.obj "F:Program FilesIntelMKL701ia32libmkl_solve r.lib" "F:Program FilesIntelMKL701ia32libmkl_c.lib"
IPO Error: unresolved : __imp__DNRM2
Referenced in Release/LoTekFEAfa.obj
IPO Error: unresolved : __imp__DDOT
IPO Error: unresolved : __imp__SNRM2
Release/LoTekFEAfa.obj:warning : locally defined symbol __imp__DGEMV imported
Link: executing 'link'
Microsoft Incremental Linker Version 7.10.3077
Copyright (C) Microsoft Corporation. All rights reserved.
/OUT:Release/LoTekFEA.exe
/INCREMENTAL:NO
"/LIBPATH:F:Program FilesIntelMKL701ia32lib"
/SUBSYSTEM:CONSOLE
mkl_c_dll.lib
"F:Program FilesIntelMKL701ia32libmkl_solver.lib"
LoTekFEAfa.obj : warning LNK4217: locally defined symbol _DGEMV imported in function _MOD_ITERATIVE_SOLVERS_EX_mp_GMRESR.J
LoTekFEAfa.obj : error LNK2019: unresolved external symbol __imp__DNRM2 referenced in function _MOD_FORM_EL_M_LIN_EX_mp_FORM_EL_M_LIN.J
LoTekFEAfa.obj : error LNK2019: unresolved external symbol __imp__DDOT referenced in function _MOD_ITERATIVE_SOLVERS_EX_mp_BICGSTAB.J
LoTekFEAfa.obj : error LNK2019: unresolved external symbol __imp__SNRM2 referenced in function _MOD_UTIL_EX_mp_VEC_NORM_V_S.J
Release/LoTekFEA.exe : fatal error LNK1120: 3 unresolved externals
LoTekFEA build failed.
I'm using /Ob2 /QaxN for optimization (default /O2).
Now, for example, "DNRM2"is referenced in several more places than just in FORM_EL_M_LIN, so why not multiple linker errors for the other many referecnces to DNRM2? In fact DNRM2 is not even directly referenced in FORM_EL_M_LIN, the reference is indirect because FORM_EL_M_LIN refernces an overloaded module procedure "vec_norm"
MODULE mod_util_ex
USE mod_ircl_intrinsic_types
PRIVATE
PUBLIC :: max_elem_nodes, &
min_elem_nodes, &
g_dof_per_node, &
el_dof_per_node, &
elem_dim, &
shell_name, &
beam_name, &
determinant, &
inv_det_23mat, &
inv_det_mat23, &
nat_nod_ord, &
nod_rst_cord, &
vec_norm, &
error_trap, &
augment, &
OPERATOR(.cross.), &
OPERATOR(.equals.), &
Form_csTrcs, &
iocs_cords, &
spline
INTERFACE vec_norm
MODULE PROCEDURE vec_norm_v_s, vec_norm_cm_s, &
vec_norm_v_d, vec_norm_cm_d
END INTERFACE vec_norm
INTERFACE OPERATOR(.cr oss.)
MODULE PROCEDURE vcrossw_s, vcrossw_d
END INTERFACE OPERATOR(.cross.)
INTERFACE OPERATOR(.equals.)
MODULE PROCEDURE equals_sgl, equals_dbl
END INTERFACE OPERATOR(.equals.)
CONTAINS
PURE FUNCTION vec_norm_v_s( vec )
USE mod_BLAS_real_int, ONLY : SNRM2
! SNRM2 ( n, x, incx )
IMPLICIT NONE
REAL(SP), INTENT(IN) :: vec(:)
REAL(SP) :: vec_norm_v_s
vec_norm_v_s = SNRM2( SIZE(vec), vec, 1 )
END FUNCTION vec_norm_v_s
PURE FUNCTION vec_norm_cm_s( arrofvec )
IMPLICIT NONE
REAL(SP), INTENT(IN) :: arrofvec(:,:)
REAL(SP) :: vec_norm_cm_s(SIZE(arrofvec,2))
INTEGER :: n, a
n = SIZE(arrofvec,1)
DO a = 1, SIZE(arrofvec,2)
vec_norm_cm_s(a) = SNRM2( n, arrofvec(:,a), 1 )
END DO
END FUNCTION vec_norm_cm_s
PURE FUNCTION vec_norm_v_d( vec )
USE mod_BLAS_real_int, ONLY : DNRM2
! DNRM2 ( n, x, incx )
IMPLICIT NONE
REAL(DP), INTENT(IN) :: vec(:)
REAL(DP) :: vec_norm_v_d
vec_norm_v_d = DNRM2( SIZE(vec), vec, 1 )
END FUNCTION vec_norm_v_d
PURE FUNCTION vec_norm_cm_d( arrofvec )
IMPLICIT NONE
REAL(DP), INTENT(IN) :: arrofvec(:,:)
REAL(DP) :: vec_norm_cm_d(SIZE(arrofvec,2))
INTEGER :: n, a
vec_norm_cm_d(a) = DNRM2( n, arrofvec(:,a), 1 )
END DO
END FUNCTION vec_norm_cm_d
and even "vec_norm" is referenced in many, many places throughout the source file.
Are the linker errors (seemingly inconsistent IMHO) a result of improper or incomplete specification of, for example
in "DNRM2"s interface?
Additionally, what's with the linker warning regarding the reference of "DGEMV"?
I will close with the observation that when I remove the DLLIMPORT properties and statically link to the mkl_c.lib for Everything that references Intel MKL that the build succeeds and the program yields correct results from an extensive suite of tests.
Brian Earl Lamm
I see you also asked this in the MKL forum. That's really the best place to get help on using MKL.
