Linking
MMukherjee
LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
andrew_4619
Well that is a fortran system lib, so either your install is broken and it is missing or more likely the link command (which you have not shown) or the environment in which you are running to not tell the linker where to look for it. If you do a google you will find plenty of answers to how to deal with this.
MMukherjee
andrew_4619
For your project add /verbose in additional options. This will show in the output window what the linker does and where it is finding things.  I note on a test I ran that :
"Searching C:\Program Files (x86)\Intel\oneAPI\compiler\2024.1\lib\ifconsol.lib:"
