29642 Discussions
Linux compiler bug? (short sample program included)
stefan_m
The simple program below performs a sum over diagonal entries in a 4-dimensional array of REAL numbers. The result should be 6.
When compiled via
ifort -r8 -O3 -o test test.f90
it gives get the correct result. However, when compiled to produce code with SSE3 via
ifort -r8 -O3 -xP -o test test.f90
the result is 1 instead of 6.
Same with ifort 9.1 and ifort 10.1, on Pentium 4 32 bit Scientific Linux 5.2 and Xeon 5160 64 bit ClusterVisionOS 2.1. Also with -xN instead of -xP on a Pentium M with OpenSUSE 10.3
Interestingly, when the order of the inner and outer loops is interchanged, the error does not appear anymore.
It would be great if someone could test this. Am I missing something?
Thanks, Stefan
PROGRAM test
IMPLICIT NONE
REAL, DIMENSION(3, 2, 3, 2) :: a
a=0.0
a(1, 1, 1, 1)=1.0
a(2, 1, 2, 1)=1.0
a(3, 1, 3, 1)=1.0
a(1, 2, 1, 2)=1.0
a(2, 2, 2, 2)=1.0
a(3, 2, 3, 2)=1.0
PRINT *, f(a)
CONTAINS
FUNCTION f(a)
REAL :: f
REAL, DIMENSION(3, 2, 3, 2), INTENT(IN) :: a
INTEGER :: c, s
f=0.0
DO s=1, 2
DO c=1, 3
f=f+a(c, s, c, s)
END DO
END DO
END FUNCTION f
END PROGRAM test
TimP
I found that ifort -O1 gave the same "correct" result as ifort -check. If you care to submit it in a problem report on premier.intel.com, it should be easy for a compiler expert to diagnose.
stefan_m
Quoting - tim18
Many thanks. Can you confirm that you also got the wrong result with -O3 -xP (or similar options)? What compiler version were you using? I'll try to submit a problem report.
TimP
Quoting - stefan_m
Yes, I found the same problem with ifort 10.1 and 11.0/044, using various options which imply auto-vectorization.
