Optimization and different servers
tomfmguy_com
Hello.
I have two questions that I was hoping you could help me with.
1.Why do I get slightly different results when I compile my code using different optimization options (-O1, -O2 and -O3)? Is this normal?
2.Why do I get slightly different results when I run my code on different servers (both linux, 64 bit, using intel fortan 10)? Is this normal?
Reagards,
Tom.
stefan_m
Dear Tom,
I'll try to answer question 1.
Does your code involve floating-point operations? If so, then: yes, this is normal. Optimization may change the order of algebraic operations. Due to round-off errors, this can lead to slightly different results (or even very different results, if your algorithm is not numerically stable). Try e.g. the compiler options
-fp-model precise
or
-fp-model strict
and see if the difference in your results gets smaller.
Best wishes,
Stefan
TimP
Quoting - tomfmguy.com
Hello.
Reagards,
Tom.
Some of the differences may be eliminated by using -prec-div -prec-sqrt -assume protect_parens. The other suggestion about -fp-model would accomplish some of the same things. I would suggest that you use ifort 10.1 or 11.0, and specify the level of SSE optimization (e.g. -xO) rather than using a -host option.
