29331 ディスカッション
List of all declared variables
afterburner
ビギナー
5,299件の閲覧回数
I have written several Subroutines within the Visual Studio integration of Intel Visual Fortran. Unfortenately I lost overview of all declared and used variables.
Is there an easy way to get a complete list of all variables which are used/declared within one or several subroutines? Would be glad for help because I have been trying to find an answer without any success.
0 件の賞賛
20 返答(返信)
Steven_L_Intel1
従業員
5,286件の閲覧回数
No, sorry. This is still on our wish-list.
anthonyrichards
新規コントリビューター III
5,286件の閲覧回数
I sem to recall such lists and calling trees being available when I was using an FTN compiler on CDC CYBER 6600/7600machines in the sixties.....Since one had to debug one's own programs manually then, such lists were essential.
Steven_L_Intel1
従業員
5,286件の閲覧回数
One thing you can try is to build an alternate configuration with Static Verifier enabled. This will warn you of undeclared or unused variables. See the on-disk documentation for details on how to do this.
hansr
ビギナー
5,286件の閲覧回数
For this and others i use ftnchek. (newline) Look at http://www.dsm.fordham.edu/~ftnchek/ (newline) Hans (newline) How can I get a linefeed? .
jimdempseyatthecove
名誉コントリビューター III
5,286件の閲覧回数
Hans,
In the forum message you use Shift-Enter
to get a return/linefeed and use Enter
to get a paragraph break.
Jim Dempsey
hansr
ビギナー
5,286件の閲覧回数
Jim, thanks, but neither Schift-Enter nor only Enter changes the line (neither Opera nor IExplorer) Hans
jimdempseyatthecove
名誉コントリビューター III
5,286件の閲覧回数
Strange,
Must be a cleaverly hidden setting.
Try writing your post in NOTEPAD or WORDPAD an then either pasting it into the message window or using the icon labled C++ to paste the text into the message window.
Jim
hansr
ビギナー
5,286件の閲覧回数
Jim, with Textpad it doesn't do. Now I follow your advice with notepad and we see the result. Thanks Hans
hansr
ビギナー
5,286件の閲覧回数
Jim, now I'm trying with notepad+ . Where can I find "the icon labled C++" ? Thanks Hans
jimdempseyatthecove
名誉コントリビューター III
5,286件の閲覧回数
Compose in notepad, Copy message to clipboard
Select all (Ctrl-A), Copy to clipboard (Ctrl-C).
Using your browser, browse to forum and message of interest, click on reply. The browser will open a message composition web page. Using IE, the last icon listed in the tool bar is a box (button) with something that looks like:
______
|C++ |
Clicking on that button pastes the clipboard into the message window with line feeds (without the larger vertical paragraph separation).
The additional advantage of using notepad is that if the dang web page times out on your composition (often does) you won't loose a nicely composed message.
Going the other way, if source code is in the forum message, and if you wish to copy into sample program, I find using WordPad a better choice as an intermediary between paste and save as.
Jim Dempsey
hansr
ビギナー
5,286件の閲覧回数
Jim, sorrrry, but there is no tool bar with a button like you described. Maybe my IE 6 is tooooo old. I try to add a screenshot. So much effort for such a ..... Thanks Hans
Jugoslav_Dujic
高評価コントリビューター II
5,286件の閲覧回数
Hm. There's supposed to be a fairly large toolbar between the "Message" title and the edit box. And I see it with both Firefox 2 and IE 6. Maybe it's due to a combination of your (Java)Script/Security/whatever settings (however, I don't know which ones, even if I'm on a right track)?
Les_Neilson
高評価コントリビューター II
5,286件の閲覧回数
Hans,
The C++ icon is not on the IE toolbar but on far right of the Intel toolbar -between "Message" and the box where I am typing now. (Seen when you click "Reply" to one of these posts)
Hopefully I have successfully attached a screenshot.
Les
Also. When I am typing here in the reply box :
ctrl-Enter goes down to next line.
Enter on its own goes down a paragraph spacing
Steven_L_Intel1
従業員
5,286件の閲覧回数
That screenshot suggests that JavaScript is disabled.
jimdempseyatthecove
名誉コントリビューター III
5,286件の閲覧回数
What I see is this--------------------------------------------------------------^
Jim
hansr
ビギナー
5,286件の閲覧回数
Now with Javascript activated: directly written in Message window. And moved from Notepad: No linefeed. Hans
hansr
ビギナー
5,286件の閲覧回数
No chance. Neither in IE 6 nor in Opera 9.24 can I get the nice toolbar showed by Les and Jim. All security points are disabled. Thank you all. Please excuse, if my further posts are without linefeeds. Hans
Steven_L_Intel1
従業員
5,286件の閲覧回数
Curious. Please go to http://centralops.net/asp/co/BrowserMirror.vbs.asp and copy and paste what it says from the header Client-Side Scripting through the line starting with "browser".
For what it's worth, this forum is likely to change to a vBulletin-based one sometime next year. This should alleviate many of the forum issues people have.
hansr
ビギナー
5,286件の閲覧回数
Steve, I attach the mirror results, because it is better readable so. (It is a nice tool). Thanks Hans
Steven_L_Intel1
従業員
5,095件の閲覧回数
Please send me an email at steve.lionel at intel.com so I can put you in touch with our forum tech support people so we can find out what is going on.
返信
