Load Failed for C projects in a mixed language solution
acar
I have recently migrated my VS2015 solution to a new computer and am having teething problems getting it to work.
I have attached an image file showing the response in VS2015 and here is a list of the products in VS2015 and it includes C++ and the Intel Visual Fortran:
Microsoft Visual Studio Professional 2015
Version 14.0.25431.01 Update 3
Microsoft .NET Framework
Version 4.7.02558
Installed Version: Professional
Visual Basic 2015   00325-60005-53699-AA785
Microsoft Visual Basic 2015
Visual C# 2015   00325-60005-53699-AA785
Microsoft Visual C# 2015
Visual C++ 2015   00325-60005-53699-AA785
Microsoft Visual C++ 2015
Application Insights Tools for Visual Studio Package   7.0.20622.1
ASP.NET and Web Tools 2015.1 (Beta8)   14.1.11107.0
ASP.NET Web Frameworks and Tools 2012.2   4.1.41102.0
For additional information, visit http://go.microsoft.com/fwlink/?LinkID=309563
ASP.NET Web Frameworks and Tools 2013   5.2.40314.0
For additional information, visit http://www.asp.net/
Common Azure Tools   1.8
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
Intel® Parallel Studio XE 2018 Update 2 Composer Edition for Fortran Windows*   Package ID: w_comp_lib_2018.2.185
Intel® Parallel Studio XE 2018 Update 2 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2015, Version 18.0.0038.14, Copyright © 2002-2018 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
JavaScript Language Service   2.0
JavaScript Project System   2.0
Microsoft Azure Mobile Services Tools   1.4
NuGet Package Manager   3.4.4
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
PreEmptive Analytics Visualizer   1.2
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
SQL Server Data Tools   14.0.60519.0
Microsoft SQL Server Data Tools
TypeScript   1.8.36.0
TypeScript tools for Visual Studio
I'd be grateful if anyone could point me to what I need to do.
Lorri_M_Intel
It is probably the case that the directory locations are different on the new computer from the old computer.
The directory paths to the projects are stored in the solution file.
Try re-adding the projects to the solution.
acar
Thanks for your suggestion Lorri.  However, as far as I am aware, I have exactly the same directory structure on the new computer that I had on the old one.  The error suggests that it has found the file but is unable to read it - although clearly it can't read it if it can't find it...
acar
PROBLEM SOLVED!!!  In using the data recovered from my old computer I have found that when opening word documents the software has to go through a short repair of the document before it opens.  This must also be the case with the VS files and hence they can be opened but not read.  I have reverted to an old version of the VS project and everything seems fine.  So, thanks for your time.
