Lock_type Compiler crash
n_kirkbysurrey_ac_uk
Got a 'please report this error' message from Fortran Composer XE 2013, then I installed upgrade 4 and still get message, code is as follows
program test_lock_type
! Code does not compile as shown
use, intrinsic :: iso_fortran_env, only: lock_type
implicit none
!code will compile if the next statement is commented out
type(lock_type), codimension
  • :: my_lock
    integer :: n_its=0
    call get_user('Enter number of iterations: ', n_its)
    !or code will compile if the next statement is commented out
    write(*,'(A,I0,A,I0)') 'Image number ', this_image(),' has n_its = ', n_its
  • contains
    subroutine get_user(text, i)
    integer, intent(out) :: i
    character (*), intent(in) :: text
    i =1
    end subroutine get_user
    end program test_lock_type
    Running under Windows 7 Home Premium, Intel Core i7 Sandy bridge (Alienware)
    Compiler produces:
    Compilation Aborted (code 1)
    But if I try to run after a failed compile i get a little more...
    Catastrophic error: ** Internal compiler error: **Internal abort Please report this error...
    I have the coarray compilation switch set, and other coarray programs compile and run fine
    Norman
    Thanks - I can reproduce the problem for what would be a Debug configuration in Visual Studio. If you set Debugging to "Minimal" it will compile. I don't see the error in the beta of our next version, to be released later this year.
