I've got Win 2K / Visual Fortran 6.6 and am trying to compile MathWorks' example file: "matdemo1.f" using:
mex -setup (sets up compiler options --- I selected Visual Fortran 6.6)
mex matdemo1.f -v (the "verbose" option is helpfulatperilous times such as this)
Result: error LNK2001: unresolved external symbol _MEXFUNCTION@16
Compilation resultsattached below.
Do you know what the problem could be?
-Bob
Code:
>> mex matdemo1.f -v This is mex, Copyright 1984-2003 The MathWorks, Inc. -> Default options filename found in C:Documents and SettingscalabrraApplication DataMathWorksMATLABR14 ---------------------------------------------------------------- -> Options file = C:Documents and SettingscalabrraApplication DataMathWorksMATLABR14mexopts.bat MATLAB = C:MATLAB7 -> COMPILER = fl32 -> Compiler flags: COMPFLAGS = /fpp:"/m /SC:MATLAB7/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed OPTIMFLAGS = /MD -Ox -DNDEBUG DEBUGFLAGS = /MDd -Zi arguments = Name switch = /Fo -> Pre-linking commands = -> LINKER = link -> Link directives: LINKFLAGS = /DLL /EXPORT:_MEXFUNCTION@16 /LIBPATH:"C:MATLAB7externlibwin32digitaldf60" libmx.lib libmex.lib libmat.lib /implib:_lib2762.lib /NOLOGO LINKFLAGSPOST = Name directive = "/out:matdemo1.dll" File link directive = Lib. link directive = Rsp file indicator = @ -> Resource Compiler = rc /fo "mexversion.res" -> Resource Linker = ---------------------------------------------------------------- --> "fl32 /fpp:"/m /SC:MATLAB7/extern/include" -c -nokeep -G5 -nologo -DMATLAB_MEX_FILE /fixed /Fomatdemo1.obj /MD -Ox -DNDEBUG matdemo1.f" matdemo1.i Contents of 2762_tmp.rsp: matdemo1.obj --> "link "/out:matdemo1.dll" /DLL /EXPORT:_MEXFUNCTION@16 /LIBPATH:"C:MATLAB7externlibwin32digitaldf60" libmx.lib libmex.lib libmat.lib /implib:_lib2762.lib /NOLOGO @2762_tmp.rsp " Creating library _lib2762.lib and object _lib2762.exp _lib2762.exp : error LNK2001: unresolved external symbol _MEXFUNCTION@16 matdemo1.dll : fatal error LNK1120: 1 unresolved externals C:MATLAB7BINWIN32MEX.PL: Error: Link of 'matdemo1.dll' failed. ??? Error using ==> mex Unable to complete successfully >> mex matdemo1.f Creating library _lib4648.lib and object _lib4648.exp _lib4648.exp : error LNK2001: unresolved external symbol _MEXFUNCTION@16 matdemo1.dll : fatal error LNK1120: 1 unresolved externals C:MATLAB7BINWIN32MEX.PL: Error: Link of 'matdemo1.dll' failed. ??? Error using ==> mex Unable to complete successfully
