MAX0 vs JMAX0
salbruce
I'm puzzled by why I get the following error in IVF 11.1:
error #6405: The same named entity from different modules and/or program units cannot be referenced. [MAX0]
if I use the function MAX0, but not if I use the function JMAX0 in something like:
ALLOCATE (X(NENT,NATT),ENT(NENT),ATT(NATT),VTYPE(MAX0(NENT,NATT)),STAT=IERR)
The error is flagged only if I have "Compile Time Diagnostics" set to "Show All (/warn:all)". If I turn that off the program compiles and appears to run correctly. I am using the MAX0 function in various subroutines in the project, but not intentionally using it as anything other than a built-in function.
NENT and NATT are implicit 4-byte integers.
From the Fortran language reference, it seems that MAX0 and JMAX0 should give the same results.
Thanks in advance for your help.
-Bruce
Can you provide a source file that generates this error? I'd guess that if you set "Check Routine Interfaces" to No that this error will go away. It sounds as if there's a bug in this feature. Please help us out with a test case.
salbruce
Yes, I will see if I can make a small example that gives this error and then post it.
Meanwhile, I tried the test you suggested and that is correct. If I set Compile Time Diagnostics to "Custom" and Check Routine Interfaces to "Yes", and the other options to "No", I get the error message. Setting Check Routine Interfaces to "No" results in no errors.
salbruce
I made several tries at a short program that produces the problem but was unsuccessful. (That is, when I whack out a lot of code the problem disappears). I'm sure I could get one eventually, but no time right now. Maybe the easiest avenue would be if I could send you a whole project privately.
That would be fine. You can attach a ZIP here and check the box to make the post Private, or submit it through Intel Premier Support and ask that it be assigned to me.
salbruce
OK, I've submitted the project through Intel Premier Support.
Bruce
Got it - thanks. I'll follow up there.
