MD5 Hash in Fortran revisit
JohnDrohan
In case anyone is trying to use the code from this forum post:
https://community.intel.com/t5/Intel-Fortran-Compiler/MD5-Hash/td-p/801183
I wanted to let folks know that there was a bug I fixed that might be helpful to someone in the future.
I changed this line of code:
character*((int(len(string)/64)+1)*64) newString
to:
character*((int((len(string)+8)/64)+1)*64) newString
The inclusion of the "+8" allows for the 8 bit length portion of the MD5 padding spec to be accounted for and prevent string overflows for strings that need fewer than 8 bits of padding.
Not that this code is being used many places....I just recently used it and had to debug/fix the issue so figured I'd post about it just in case.
wtstephens
Thanks for that fix!  Also had to fix the "blank" rather than "0" bug in the original code -- using a "z8.8" format.
Then turned it into a module. Here it is:
module md5_hash
contains
character*32 function md5(string)
!     Programmierer    : VEZ2/Pieper                                   *
!     Version          : 1.0                                           *
!     letzte nderung  : 07.05.2010                                     *
!     Aufgabe          : Erzeugt aus einem String einen MD5 Hashwert   *
implicit none
character*(*), intent(in) :: string
character*8 wtmp
integer(kind=4) j,n1,n2,n3,n4,pos
integer(kind=4) r(64),k(64),h0,h1,h2,h3,a,b,c,d,f,g,temp,w(16),i,intLen
integer(kind=8) hoch32
real(kind=8) sinus,absolut,real8i
r = [ 7, 12, 17, 22,  7, 12, 17, 22,  7, 12, 17, 22,  7, 12, 17, 22, &
      5,  9, 14, 20,  5,  9, 14, 20,  5,  9, 14, 20,  5,  9, 14, 20, &
      4, 11, 16, 23,  4, 11, 16, 23,  4, 11, 16, 23,  4, 11, 16, 23, &
      6, 10, 15, 21,  6, 10, 15, 21,  6, 10, 15, 21,  6, 10, 15, 21]
do i=1,64
    real8i = floatk(int8(i))
    sinus = dsin(real8i)
    absolut = dabs(sinus)
    hoch32 = 2.**32.
    k(i) = int8(absolut * floatk(hoch32))
enddo
h0 = #67452301
h1 = #EFCDAB89
h2 = #98BADCFE
h3 = #10325476
j = len(string)+1
newString(:j) = string // char(128)
i = mod(j, 64)
do while(i /= 56)
    j = j + 1
    newString(j:j) = char(0)
    i = mod(j, 64)
enddo
intLen = len(string)*8
do i = 0,3
    temp = intLen .and. #FF
    j = j + 1
    newString(j:j) = char(temp)
    intLen = shiftr(intLen, 8)
enddo
do i = 1,4
    j = j + 1
enddo
do i = 1,int(len(newString)/64)
    do j = 1,16
        pos = (j-1)*4+(i-1)*64
        n1 = ichar(newString(4+pos:4+pos))
        n2 = ichar(newString(3+pos:3+pos))
        n3 = ichar(newString(2+pos:2+pos))
        n4 = ichar(newString(1+pos:1+pos))
        write(wtmp,'(4(z2.2))') n1,n2,n3,n4
        read(wtmp,'(z8)') w(j)
    enddo
    a = h0
    b = h1
    c = h2
    d = h3
    do j = 1,64
        if (j >= 1 .and. j <= 16) then
            f = (b .and. c) .or. ((.not. b) .and. d)
            g = j
        else if (j >= 17 .and. j <= 32) then
            f = (d .and. b) .or. ((.not. d) .and. c)
            g = mod(5*(j-1) + 1, 16) + 1
        else if (j >= 33 .and. j <= 48) then
            f = ieor(b, ieor(c, d))
            g = mod(3*(j-1) + 5, 16) + 1
        else if (j >= 49 .and. j <= 64) then
            f = ieor(c, (b .or. (.not. d)))
            g = mod(7*(j-1), 16) + 1
        endif
        temp = d
        d = c
        c = b
        b = b + leftrotate((a + f + k(j) + w(g)) , r(j))
        a = temp
    enddo
    h0 = h0 + a
    h1 = h1 + b
    h2 = h2 + c
    h3 = h3 + d
enddo
h0 = umdrehen(h0)
h1 = umdrehen(h1)
h2 = umdrehen(h2)
h3 = umdrehen(h3)
write(md5,'(4(z8.8))') h0,h1,h2,h3
return
endfunction
pure function leftrotate (x, c) result(i4value)
!     Version          : 1.0                                           *
!     Aufgabe          : Fhrt ein Leftrotate der Bits durch            *
implicit none
integer*4, intent(in) :: x, c
integer*4 :: i4value
integer*4 result1,result2
result1 = shiftl(x,c)
result2 = shiftr(x, (32-c))
i4value = result1 .or. result2
return
endfunction
pure function umdrehen(zahl_input) result(i4value)
!     Version          : 1.0                                           *
!     Aufgabe          : Macht aus Big Endian -> Little Endian Bits    *
implicit none
integer*4, intent(in) :: zahl_input
integer*4 i,tmp,zahl
zahl = zahl_input
i4value = 0
do i = 1,4
    i4value = shiftl(i4value, 8)
    tmp = zahl .and. #FF
    i4value = i4value + tmp;
    zahl = shiftr(zahl, 8)
enddo
return
endfunction
endmodule
Here is a test program:
program md5_test
    use md5_hash
    character*32 md5_test_1 / "9EAB500708CAD82AAD8E156BDA5ED03A" /
    character*32 md5_test_2 / "F2F8F10BE9359F85503A242DE2E0665B" /
    character*32 md5_test_3 / "7215EE9C7D9DC229D2921A40E899EC5F" /
    character*32 c32
    character*100 ctest
    ctest = "TestString1"
    c32 = md5(trim(ctest))
    if( c32 /= md5_test_1 )then
        write(*,'(4A)') 'Mismatch! md5=',c32,' vs ',md5_test_1
    else
        write(*,'(4A)') 'Test #1 of md5 is Ok! md5("',trim(ctest),'") is: ',c32
    endif
    write(*,*)
    ctest = "SecondTestString"
    if( c32 /= md5_test_2 )then
        write(*,'(4A)') 'Mismatch! md5=',c32,' vs ',md5_test_2
    else
        write(*,'(4A)') 'Test #2 of md5 is Ok! md5("',trim(ctest),'") is: ',c32
    endif
    write(*,*)
    c32 = md5(" ")
    if( c32 /= md5_test_3 )then
        write(*,'(4A)') 'Mismatch! md5=',c32,' vs ',md5_test_3
    else
        write(*,'(4A)') 'Test #3 of md5 is Ok! md5(" ") is: ',c32
    endif
endprogram
Which I compared to output from the Windows certutil utility program:
certutil -hashfile testfile.txt md5
