MINLOC
Mike896
Hi
following adapted from Help on MINLOC
INTEGER i, minl(1)
INTEGER array(2, 3)
INTEGER, ALLOCATABLE :: AR1(:)
! put values in array
array = RESHAPE((/-7, 1, -2, -9, 5, 0/),(/2, 3/))
! array is -7 -2 5
! 1 -9 0
i = SIZE(SHAPE(array)) ! Get the number of dimensions
! in array
ALLOCATE (AR1 (i) ) ! Allocate AR1 to number
! of dimensions in array
AR1 = MINLOC (array, MASK = array .GT. -5) ! Get the
! location (subscripts) of
! smallest element greater
! than -5 in array
! MASK = array .GT. -5 creates a mask array the same
! size and shape as array whose elements are .TRUE. if
! the corresponding element in array is greater than
! -5, and .FALSE. if it is not. This mask causes MINLOC
! to return the index of the element in array with the
! smallest value greater than -5.
!array is -7 -2 5 and MASK= array .GT. -5 is F T T
! 1 -9 0 T F T
! and AR1 = MINLOC(array, MASK = array .GT. -5) returns
! (1, 2), the location of the element with value -2
minl = MINLOC((/-7,2,-7,5/)) ! returns 1, first
! occurrence of minimum
print *,min1
END
The result is 0.
Why?
Thank you in advance.
Mike
TimP
You have changed the spelling from minl to min1, and you may have meant to use the form of MINLOC with a 2nd argument MINLOC(array,dim=1). IMPLICIT NONE should have forced the compiler to perform some checking.
Mike896
Quoting - tim18
Oh! so embarrassing.
Thank you.
Mike
