updated project?
Mike896
Hi
I have modified a Static_Library project inside one solution by adding some files.
I expect this project will be updated in other solutions which uses it.
But I found it's not.
How to do it?
Mike
DavidWhite
Valued Contributor II
Mike,
I think I have got around this by adding the project for the library to the solution for the main project. You then need to make sure that the dependencies are set so that the main project depends on the library.
This way the solution is rebuilt when any of the other project are modified, even if they are modified externally to the main project solution.
David
Mike896
Quoting - David White
Mike,
David
Yes, it works.
Thank you for your help.
Mike
