29487 Discussions
MKL, DSS & IPO -> ifort: error #10014: problem during multi-file optimization compilation (code 3)
Alexandre_Correia
Hi everyone,
We are working with Fortran code which implements MKL Direct Sparse Solver (DSS) and some OpenMP directives. Until the previous release of our code, It was working 100% in terms of compiling & linking the code with compiler options for fastest performance (/O3 /Qipo /Qprec-div- /QaxSSE4.1,SSSE3,SSE3 /arch:IA32) when It finds the specific processor.
But for the new release of our code we are experiencing an error of Interprocedural Optimization (IPO) as showed below:
We were looking for in our code and apparently we have no errors on changed part of code. In this way, we are being obligated to compile with NO /Qipo option.
Any idea?
We are using:
* Windows XP 32 bits SP 3.
* Intel Dual core processor (compatible SSSE3 instructions) to compilation the code.
* Intel Quad core processor (compatible SSE4.1 instructions) to run out the code.
* Intel Fortran 11.1 update 2.
here is the content of the BAT file for compiling the code
  • SET my_MKL_PATH=C:\\Intel\\Compiler\\11.1\\048\\mkl
  • SET my_COMMOM_OPT=^/I:^"%my_MKL_PATH%\\include^" ^/fixed:NO ^/4L132 ^/fpp ^/D_MKL ^/O3 ^/Qipo ^/Qprec-div- ^/QaxSSE4.1,SSSE3,SSE3 ^/arch:IA32
  • SET my_MKL_ARCH_LIB=^"%my_MKL_PATH%\\ia32\\lib\\mkl_solver.lib^" ^"%my_MKL_PATH%\\ia32\\lib\\mkl_intel_c_dll.lib^" ^"%my_MKL_PATH%\\ia32\\lib\\mkl_intel_thread_dll.lib^" ^"%my_MKL_PATH%\\ia32\\lib\\mkl_core_dll.lib^"
  • ifort %my_COMMOM_OPT% /Qopenmp-report2 /Qdiag-disable:cpu-dispatch /Qopenmp /c *.f
  • ifort /nologo %my_COMMOM_OPT% /Qopenmp-report2 /Qdiag-disable:cpu-dispatch /Qopenmp /c *.FOR
  • ifort %my_COMMOM_OPT% /Qopenmp-report2 /Qdiag-disable:cpu-dispatch /Qopenmp %my_MKL_ARCH_LIB% /exe:our_code_fast_dss_omp *.obj
Thanks in advance
TimP
I suppose we'll need more detail, if more detail doesn't already help you find your problem. Assuming that there are problems before the final step of the build, those messages would be important. If not, it would be interesting to know if removing some of the more complicated options would remove the error.
As Tim suggests, that 10014 error usually follows one or more other errors. What are they?
Have you tried with Update 5?
Alexandre_Correia
My apologize for the long time to response. It worked fine with version 11.1 update 5. Many thanks.
Computer system
- Windows XP SP 3 - 32 bits
- Microsoft Visual Studio 2005
- Processor specs
Name Intel Mobile Core 2 Duo T5600
Codename Merom
Specification Intel Core2 CPU T5600 @ 1.83GHz
Package Socket 479 mPGA (platform ID = 5h)
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
BAT file command line
REM ## Environment variables ##
SET my_MKL_PATH=C:\Intel\Compiler\11.1\048\mkl
SET my_COMMOM_OPT=/I:^"%my_MKL_PATH%\include^" ^/fixed:NO ^/4L132 ^/fpp ^/D_MKL ^/O3 ^/Qipo ^/Qprec-div- ^/QaxSSE4.1,SSSE3,SSE3 ^/arch:IA32
SET my_MKL_ARCH_LIB=^"%my_MKL_PATH%\ia32\lib\mkl_solver.lib^" ^"%my_MKL_PATH%\ia32\lib\mkl_intel_c_dll.lib^" ^"%my_MKL_PATH%\ia32\lib\mkl_intel_thread_dll.lib^" ^"%my_MKL_PATH%\ia32\lib\mkl_core_dll.lib^"
REM ## compiling phase ##
ifort %my_COMMOM_OPT% /Qopenmp /Qopenmp-report /c *.f
ifort /nologo %my_COMMOM_OPT% /Qopenmp /Qopenmp-report /c *.FOR
REM ## linking phase ##
ifort %my_COMMOM_OPT% /Qopenmp /Qopenmp-report /Qdiag-disable:cpu-dispatch %my_MKL_ARCH_LIB% /exe:our_code_DSS_omp *.obj
Compiling & Linking with Intel Fortran 11.1 update 2
F:\data\dem\dd3imp\o11>f
Intel Visual Fortran Compiler Professional for applications running on IA-32,
Version 11.1 Build 20090930 Package ID: w_cprof_p_11.1.048
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
ipo: remark #11000: performing multi-file optimizations
ipo: remark #11005: generating object file f:\temp\ipo_3252.obj
F:\data\dem\dd3imp\o11\src\itereq.for(271): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
F:\data\dem\dd3imp\o11\src\itereq.for(267): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
F:\data\dem\dd3imp\o11\src\itereq.for(347): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
F:\data\dem\dd3imp\o11\src\itereq.for(346): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
F:\data\dem\dd3imp\o11\src\gestae.for(102): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
F:\data\dem\dd3imp\o11\src\gestae.for(97): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
backend signals
Severe: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
Compiling & Linking with Intel Fortran 11.1 update 5
C:\home\o11>f
Version 11.1 Build 20100203 Package ID: w_cprof_p_11.1.060
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
ipo: remark #11005: generating object file C:\DOCUME~1\gt\LOCALS~1\Temp\ipo_3128.obj
C:\home\o11\src\itereq.for(271): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:\home\o11\src\itereq.for(267): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
C:\home\o11\src\itereq.for(347): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:\home\o11\src\itereq.for(346): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
C:\home\o11\src\gestae.for(102): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:\home\o11\src\gestae.for(97): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
!The code only works until this point on Update 2 version!
C:\home\o11\src\gestat.for(38): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:\home\o11\src\gestat.for(34): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
C:\home\o11\src\gesta.for(89): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:\home\o11\src\gesta.for(82): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
C:\home\o11\src\tangsm.for(153): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:\home\o11\src\tangsm.for(149): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
C:\home\o11\src\dermin.for(45): (col. 7) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:\home\o11\src\dermin.for(42): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
Microsoft Incremental Linker Version 8.00.50727.42
Copyright (C) Microsoft Corporation. All rights reserved.
-out:our_code_DSS_omp.exe
-subsystem:console
-nodefaultlib:libiompprof5mt.lib
-nodefaultlib:libiompprof5md.lib
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
-fixed:NO
"C:\Program Files\Intel\Compiler\11.1\060\mkl\ia32\lib\mkl_solver.lib"
"C:\Program Files\Intel\Compiler\11.1\060\mkl\ia32\lib\mkl_intel_c_dll.lib"
"C:\Program Files\Intel\Compiler\11.1\060\mkl\ia32\lib\mkl_intel_thread_dll.lib"
"C:\Program Files\Intel\Compiler\11.1\060\mkl\ia32\lib\mkl_core_dll.lib"
C:\home\o11>
Both computers have the same system
- Processor specs
Codename Merom
ifort %my_COMMOM_OPT% /Qopenmp /Qopenmp-report /c mod_parameters.f mod*.f
ifort %my_COMMOM_OPT% /Qopenmp /Qopenmp-report /Qdiag-disable:cpu-dispatch %my_MKL_ARCH_LIB% /exe:_DD3IMP_o11_MKL_omp *.obj
backend signals
C:\home\o11>f
C:\home\o11\src\gestae.for(97): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED. !On update 2 version only works until this point!
-out:_DD3IMP_o11_MKL_omp.exe
-subsystem:console
-fixed:NO
C:\home\o11>
Glad to hear it.
