MOVE_ALLOC issue
John4
Valued Contributor I
When I try to compile the code below, I get an error that points MOVE_ALLOC as a non-pure procedure. Is that the real issue (i.e., a bug), or maybe there's something else wrong in the code that I fail to detect?
Thanks!
[vb]module mod2
    implicit none
contains
    pure subroutine reallocate(array, bound)
        real, allocatable, intent(INOUT) :: array(:)
        real, allocatable :: aux(:)
        integer, intent(IN) :: bound
        integer :: ub
    continue
        if (ALLOCATED(array)) then
            ub = SIZE(array)
             call MOVE_ALLOC(array, aux)
             allocate(array(1:bound))
             array(1:MIN(ub, bound)) = aux(1:MIN(ub, bound))
             deallocate(aux)
        else
        endif
    end subroutine
end module mod2
[/vb]
Steven_L_Intel1
Yes - fixed in 11.1.
Steven_L_Intel1
Wow. How did we miss that one? Compiler bug. MOVE_ALLOC is pure. It and MVBITS are the only pure intrinsic subroutines. I'll report that to the developers.
Andrew_Smith
Has this been fixed yet?
Steven_L_Intel1
