Is there a way to check how much memory I'm using? I saw this code for the g95 standard but it won't run on MS 4.0. Not sure how to modify it.
MODULE meminfo
MODULE meminfo
USE ISO_C_BINDING, ONLY : C_LONG_LONG
IMPLICIT NONE
PRIVATE
! the KIND might dependent on g95 version/architecture
INTEGER(KIND=C_LONG_LONG), BIND(C, NAME='_g95_total_alloc') ::
total_memory
PUBLIC :: total_memory
END MODULE meminfo
USE meminfo, ONLY: total_memory
INTEGER, PARAMETER :: N=16
TYPE T
INTEGER, DIMENSION(:), POINTER :: scratch
END TYPE T
TYPE(T) :: data(N)
write(6,*) "Total memory used: ",total_memory/(1024*1024),"Mb"
DO i=1,N
ALLOCATE(data(i)%scratch(128*1024*1024))
ENDDO
DO i=1,N
DEALLOCATE(data(i)%scratch)
ENDDO
END
"g95 standard"???
That program uses some specific routine that's part of the g95 library (as well as a Fortran 2003 feature, C interoperability, that PowerStation doesn't have.)
You could try modifying the following which possibly could be made to work under FPS4. I don't remember if FPS4 had INTEGER(8). You'll need to replace the "kernel32" with "msfwin".
Perhaps it's time to move to a current, supported compiler such as Intel Visual Fortran.
program MemoryStatus
use kernel32
implicit none
type (T_MEMORYSTATUS) :: stat
call GlobalMemoryStatus (stat)
write (*,'(I0,A)') stat%dwMemoryLoad, '% of memory is in use'
write (*,'(A,A)') trim(gv(stat%dwTotalPhys)), ' total physical memory'
write (*,'(A,A)') trim(gv(stat%dwAvailPhys)), ' available physical memory'
write (*,'(A,A)') trim(gv(stat%dwTotalPageFile)), ' total pageable memory'
write (*,'(A,A)') trim(gv(stat%dwAvailPageFile)), ' available pageable memory'
write (*,'(A,A)') trim(gv(stat%dwTotalVirtual )), ' total virtual memory'
write (*,'(A,A)') trim(gv(stat%dwAvailVirtual )), ' available virtual memory'
contains
function gv (val)
use kernel32, only: SIZE_T
character(30) gv
integer(SIZE_T), intent(in) :: val
integer(8), parameter :: DIV = 1024
integer(8) :: lval
lval = zext(val,8)
if (val == -1) then
gv = '(unrepresentable)'
else if (lval < 1024) then
write (gv, 101) lval, ' bytes'
101 format (I0,A)
else if (lval < (DIV*DIV)) then
write (gv,101) lval/DIV, 'KB'
else if (lval < (DIV*DIV*DIV)) then
write (gv,101) lval/(DIV*DIV), 'MB'
else
write (gv,102) REAL(lval/(DIV*DIV))/REAL(DIV), 'GB'
102 format (F20.2,A)
gv = adjustl(gv)
end if
end function gv
end program MemoryStatus
use kernel32
implicit none
contains
function gv (val)
character(30) gv
integer(8) :: lval
lval = zext(val,8)
if (val == -1) then
101 format (I0,A)
else
gv = adjustl(gv)
end if
end function gv
