29425 Discussions
MSVS won't open a recently used solution file
DavidWhite
Valued Contributor II
Has anyone come across this issue or have a solution to it:
1. MSVS works normally, opening the last opened solution, as per the settings.
2. I then attempt to reopen another solution in my list of recently used solutions, but nothing happens.
The system is Win 10 with MSVS 2017 (15.9.4) and Intel PSXE 2019 Update 1
File / Open Project/Solution and migrating to the solution location works properly.
None of my projects or solution files have been moved from their current locations for a long time, so there has not been a change of path, or anything like that.
David
mecej4
The problem is probably caused by your using a newer version of VS2017 (namely, 15.9.4) than the newest that Intel's VS integration is compatible with (15.8, according to https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/784330 )
See this long thread, where the compatibility problems were reported and discussed by many users: https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/784330 .
