29487 Discussions
Mac os intel fortran: idb works but frequently "Thread received signal ILL" or "BUS"
mattnotting
I used "ifort -w -g -save-temps -no_pie" to compile my program under Mac os 10.7.2. My intel fortran version is Compose XE 2011. This time idb can be started because of "-no_pie". However, under idb, when I "next/step in" my excutables step by step, it is frequently and unexpectedly interrupted by "Thread received signal ILL" or "Thread received signal BUS", or something like that. Interestingly, the excutables generated by ifort can run smoothly and achieve the correct results without any problems.So then I chose a suse linux system and still use intel fortran but 9.0 version, idb can work smoothly and never receives any signals like "ILL" or "BUS". So I guess it is the problem of Composer 2011 or Mac OS 10.7.Who can help me? Thanks in advance.Jianghui
Ron_Green
have you tried compiling with -heap-arrays as described here: http://software.intel.com/en-us/articles/determining-root-cause-of-sigsegv-or-sigbus-errors/
mattnotting
Yes, I've tried that. But the problems are still there.
I note that when I run my executables, there are no such problems. These errors only occur when I use idb to debug my program.
Jianghui
Ron_Green
There is a bug against stepping with IDB on Lion. DPD200176973. Here is the description, does this sound similar to what you are seeing? And you are using the latest 12.1 Composer XE 2011 Update 8 compiler, correct?
"no_pie helps to load the executable in idb and I can set a break point or run it. However, I don't seem to be able to step it (step or next). It just hangs. When I try stepi or nexti, it doesn't hang, but I only seem to step to the location where I have my breakpoint. If I remove the breakpoint and continue it exits "
Georg_Z_Intel
Hello Jianghui,
that's an interesting sighting. Do you see this behavior with simpler applications, you could provide, as well?
If yes, I'd like to ask you to provide the source + binary for which you see those problems. Our debugger engineers can then try to reproduce the problem. They did not hear about problems like that so far.
Thank you very much,
Georg Zitzlsberger
mattnotting
Something like this. However, when I try stepi or nexti, it still received signal BUS or ILL. Even if I removed the breakpoints and continue, it still receved BUS and ILL.
I will attach a simple code for you to test. I think the problem is related to too large temporary array.
mattnotting
Hello Georg,
I attached two files here: fout.f90 (main program) and sps.f90 (called subroutine). I used "ifort -w -g -save-temps -no_pie fout.f90 sps.f90 -o fout" to complie them. I then use "idb ./fout" to debug them. NOTE: my Mac os is 10.7.2 and my intel fortran is a trial version Composer XE 2011 (12.1.2).
After you enter idb environment, you can set "stop at 7", namely the first call of sps. Then enter "run". As expected, the program will stop at the 7th line. Then you can enter "next". You will see that
The "next" command was not completed.
stopped at [subroutine fout():6 0x0000000100000c6e]
6 allocate(a(2000,2000))
If you add "-heap-arrays" in ifort to compile them, you can repeat the above debug process. After "next", the debugger is fine. Then continue to enter a "next", you will see
I need to note that if I don't debug this program, I just run "./fout". THe program can run smoothly.
I guess the problem is the repeated call of sps, a large allocagted array and a transformation of 2-d array to 1-d array when call sps.
Looking forward to your reply. I'm working on a big project. It's quite urgent. THanks.
Jianghui
mattnotting
Hi Georg, I add some more files, including the binaries you asked for. Jianghui
Georg_Z_Intel
Hello Jianghui,
thank you!
I'll talk with the responsible engineer this afternoon. Let's hope we can reproduce it on our side. We'll start with the binary you're about to provide have provided.
Georg Zitzlsberger
mattnotting
Goerg, could I know the progress of the solution? Thanks a lot. Jianghui
Georg_Z_Intel
Hello Jianghui,
with the binary you provided I was able to reproduce the same problem. However, if I compile it myself (with a slightly older compiler version) it does not appear. I'm currently checking the latest version and try narrow down the problem: I guess it's the combination of Xcode* & compiler that unveils this problem.
While I'm at it: which Xcode* version are you using?
Georg Zitzlsberger
mattnotting
Helle Georg, my xcode version is 4.2.1 (4D502). My intel compiler is 12.1.2 and my idb version is 12.1.
Yes. I think the older version of intel fortran compiler doesn't have this problem. I used to use version 10 to compile and debug my programs under suse linux 10.3, and there was never any problems.
Thanks a lot for your help.
Jianghui
Georg_Z_Intel
Hello Jianghui,
after updating Xcode to 4.2.1 I'm not seeing the problem with your binary anymore.
To help me reconstruct your system configuration I'd like to ask you for the following:
i) Please extend fout.f90 by the following:
[fortran]program fout
implicit none
real*8,allocatable:: a(:,:)
integer aerr
allocate(a(20,20), stat=aerr)
write(*,*) aerr
call sps(a)
write(*,*) a(1:9,1)
call sps(a)
write(*,*) a(1:9,1)
call sps(a)
write(*,*) a(1:9,1)
call sps(a)
write(*,*) a(1:9,1)
deallocate(a)
stop
end[/fortran]
Print-out of aerr should be 0 with normal execution.
ii) What's the output of:
ifort -w -g -save-temps -fpic fout.f90 sps.f90 -o fout -Wl,-no_pie -#
iii) If you start the debugger and repeat the steps you mentioned, what is the value of aerr (first print-out on console) and what's the result of "print a" (print-out of allocated array). The latter should print correct values and not "".
Georg Zitzlsberger
mattnotting
Hi Georg,
I've just tried your suggestions. These are my output:
1) Yes. the 'aerr' is 0
2) The output is
/usr/bin/ifort-2011-base/bin/intel64/fortcom \
-D__INTEL_COMPILER=1210 \
-D__x86_64 \
-D__x86_64__ \
-D_MT \
-D__INTEL_COMPILER_BUILD_DATE=20111207 \
-D__PIC__ \
-D__APPLE__ \
-D__MACH__ \
-D__pentium4 \
-D__pentium4__ \
-D__tune_pentium4__ \
-D__SSE2__ \
-D__SSE3__ \
-D__SSSE3__ \
-D__SSE__ \
-D__MMX__ \
-mGLOB_pack_sort_init_list \
-I. \
-I/usr/bin/ifort-2011-base/compiler/include/intel64 \
-I/usr/bin/ifort-2011-base/compiler/include \
-I/usr/local/include \
-I/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/include \
-I/usr/include \
"-fp_modbits honor_f32_conversion" \
"-fp_modbits honor_f64_conversion" \
-O0 \
-g2 \
"-warn none" \
-simd \
-mP1OPT_version=12.1-intel64 \
-mGLOB_diag_file=fout.diag \
-mGLOB_diag_use_message_catalog=FALSE \
-mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \
-mGLOB_tune_for_fort \
-mGLOB_use_fort_dope_vector \
-mP2OPT_static_promotion \
-mP1OPT_print_version=FALSE \
-mCG_use_gas_got_workaround=F \
-mP2OPT_align_option_used=TRUE \
-mGLOB_gcc_version=421 \
"-mGLOB_options_string=-w -g -save-temps -fpic -o fout -WI,-no_pie -#" \
-mGLOB_position_independent_code \
-mGLOB_preemption_model=1 \
-mGLOB_no_compact_unwind=TRUE \
-mGLOB_cxx_limited_range=FALSE \
-mP3OPT_emit_line_numbers \
-mP2OPT_suppress_unreferenced_locals=FALSE \
-mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL \
-mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF20 \
-mP3OPT_dwarf_format=P3OPT_DWARF_FORMAT_OBJ_ONLY \
-mGLOB_as_output_backup_file_name=fout_as_.s \
-mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 \
-mGLOB_product_id_code=0x22006d8c \
-mGLOB_maintain_errno \
-mGLOB_noinline_intrinsics \
-mGLOB_use_base_pointer \
-mCG_bnl_movbe=T \
-mGLOB_extended_instructions=0x80 \
-mGLOB_advanced_optim=TRUE \
-mP3OPT_use_mspp_call_convention \
-mP2OPT_subs_out_of_bound=FALSE \
-mGLOB_ansi_alias \
-mIPOPT_ninl_limit=0 \
-mIPOPT_ninl_user_level=0 \
-mPGOPTI_value_profile_use=T \
-mP2OPT_gen_linux_const_pooling=FALSE \
-mP2OPT_il0_array_sections=TRUE \
-mGLOB_opt_level=0 \
-mIPOPT_args_in_regs=0 \
-mGLOB_imf_mapping_library=/usr/bin/ifort-2011-base/bin/intel64/libiml_attr.dylib \
-mIPOPT_obj_output_file_name=fout.o \
-mGLOB_long_size_64 \
-mGLOB_routine_pointer_size_64 \
-mGLOB_os_target=GLOB_OS_TARGET_MACH \
-mGLOB_async_unwind_tables=TRUE \
-mGLOB_obj_output_file=fout.o \
-mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \
-mP1OPT_source_file_name=fout.f90 \
-mP2OPT_symtab_type_copy=true \
fout.f90
-D__x86_64 \
-D__x86_64__ \
-D_MT \
-D__PIC__ \
-D__APPLE__ \
-D__MACH__ \
-D__pentium4 \
-D__pentium4__ \
-D__SSE2__ \
-D__SSE3__ \
-D__SSSE3__ \
-D__SSE__ \
-D__MMX__ \
-I. \
-I/usr/include \
-O0 \
-g2 \
"-warn none" \
-simd \
-mCG_bnl_movbe=T \
-mGLOB_ansi_alias \
-mIPOPT_obj_output_file_name=sps.o \
-mGLOB_obj_output_file=sps.o \
-mP1OPT_source_file_name=sps.f90 \
sps.f90
ld \
-lcrt1.10.6.o \
-dynamic \
-arch \
x86_64 \
-weak_reference_mismatches \
non-weak \
-macosx_version_min \
10.7.2 \
-no_compact_unwind \
-o \
fout \
/usr/bin/ifort-2011-base/compiler/lib/for_main.o \
-L/usr/bin/ifort-2011-base/compiler/lib \
-L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/x86_64/ \
-L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64/ \
-L/usr/lib/ \
-L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/x86_64 \
-L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/ \
-L/usr/llvm-gcc-4.2/bin/../lib/gcc/ \
-L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64 \
-L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/ \
-L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/../../../ \
-L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/../../.. \
fout.o \
sps.o \
/usr/bin/ifort-2011-base/compiler/lib/libifport.a \
/usr/bin/ifort-2011-base/compiler/lib/libifcore.a \
/usr/bin/ifort-2011-base/compiler/lib/libimf.a \
/usr/bin/ifort-2011-base/compiler/lib/libsvml.a \
/usr/bin/ifort-2011-base/compiler/lib/libipgo.a \
-lgcc \
-lgcc_s.10.5 \
-lgcc \
-lSystem \
/usr/bin/ifort-2011-base/compiler/lib/libirc.a \
-lpthread \
-ldl
dsymutil \
fout
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifort8eLYE1libgcc
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortkpd8Srgnudirs
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortwbrZquos
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortdDQZkrtos
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortJEO0mDdashv
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortH4ySgtgdb_v
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortYSSueEarg
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortpNMEthos
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortxseZF8tos
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortgZ7gWFgdb_v
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//ifortoxf7Zaarg
rm /var/folders/ds/q_w20grj6p7dv4nbrm37_79400010q/T//iforthI17YYgnudirs
/usr/bin/ifort-2011-base/bin/intel64/fortcom \ -D__INTEL_COMPILER=1210 \ -D__x86_64 \ -D__x86_64__ \ -D_MT \ -D__INTEL_COMPILER_BUILD_DATE=20111207 \ -D__PIC__ \ -D__APPLE__ \ -D__MACH__ \ -D__pentium4 \ -D__pentium4__ \ -D__tune_pentium4__ \ -D__SSE2__ \ -D__SSE3__ \ -D__SSSE3__ \ -D__SSE__ \ -D__MMX__ \ -mGLOB_pack_sort_init_list \ -I. \ -I/usr/bin/ifort-2011-base/compiler/include/intel64 \ -I/usr/bin/ifort-2011-base/compiler/include \ -I/usr/local/include \ -I/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/include \ -I/usr/include \ "-fp_modbits honor_f32_conversion" \ "-fp_modbits honor_f64_conversion" \ -O0 \ -g2 \ "-warn none" \ -simd \ -mP1OPT_version=12.1-intel64 \ -mGLOB_diag_file=fout.diag \ -mGLOB_diag_use_message_catalog=FALSE \ -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \ -mGLOB_tune_for_fort \ -mGLOB_use_fort_dope_vector \ -mP2OPT_static_promotion \ -mP1OPT_print_version=FALSE \ -mCG_use_gas_got_workaround=F \ -mP2OPT_align_option_used=TRUE \ -mGLOB_gcc_version=421 \ "-mGLOB_options_string=-w -g -save-temps -fpic -o fout -WI,-no_pie -#" \ -mGLOB_position_independent_code \ -mGLOB_preemption_model=1 \ -mGLOB_no_compact_unwind=TRUE \ -mGLOB_cxx_limited_range=FALSE \ -mP3OPT_emit_line_numbers \ -mP2OPT_suppress_unreferenced_locals=FALSE \ -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL \ -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF20 \ -mP3OPT_dwarf_format=P3OPT_DWARF_FORMAT_OBJ_ONLY \ -mGLOB_as_output_backup_file_name=fout_as_.s \ -mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 \ -mGLOB_product_id_code=0x22006d8c \ -mGLOB_maintain_errno \ -mGLOB_noinline_intrinsics \ -mGLOB_use_base_pointer \ -mCG_bnl_movbe=T \ -mGLOB_extended_instructions=0x80 \ -mGLOB_advanced_optim=TRUE \ -mP3OPT_use_mspp_call_convention \ -mP2OPT_subs_out_of_bound=FALSE \ -mGLOB_ansi_alias \ -mIPOPT_ninl_limit=0 \ -mIPOPT_ninl_user_level=0 \ -mPGOPTI_value_profile_use=T \ -mP2OPT_gen_linux_const_pooling=FALSE \ -mP2OPT_il0_array_sections=TRUE \ -mGLOB_opt_level=0 \ -mIPOPT_args_in_regs=0 \ -mGLOB_imf_mapping_library=/usr/bin/ifort-2011-base/bin/intel64/libiml_attr.dylib \ -mIPOPT_obj_output_file_name=fout.o \ -mGLOB_long_size_64 \ -mGLOB_routine_pointer_size_64 \ -mGLOB_os_target=GLOB_OS_TARGET_MACH \ -mGLOB_async_unwind_tables=TRUE \ -mGLOB_obj_output_file=fout.o \ -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \ -mP1OPT_source_file_name=fout.f90 \ -mP2OPT_symtab_type_copy=true \ fout.f90
/usr/bin/ifort-2011-base/bin/intel64/fortcom \ -D__INTEL_COMPILER=1210 \ -D__x86_64 \ -D__x86_64__ \ -D_MT \ -D__INTEL_COMPILER_BUILD_DATE=20111207 \ -D__PIC__ \ -D__APPLE__ \ -D__MACH__ \ -D__pentium4 \ -D__pentium4__ \ -D__tune_pentium4__ \ -D__SSE2__ \ -D__SSE3__ \ -D__SSSE3__ \ -D__SSE__ \ -D__MMX__ \ -mGLOB_pack_sort_init_list \ -I. \ -I/usr/bin/ifort-2011-base/compiler/include/intel64 \ -I/usr/bin/ifort-2011-base/compiler/include \ -I/usr/local/include \ -I/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/include \ -I/usr/include \ "-fp_modbits honor_f32_conversion" \ "-fp_modbits honor_f64_conversion" \ -O0 \ -g2 \ "-warn none" \ -simd \ -mP1OPT_version=12.1-intel64 \ -mGLOB_diag_file=fout.diag \ -mGLOB_diag_use_message_catalog=FALSE \ -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \ -mGLOB_tune_for_fort \ -mGLOB_use_fort_dope_vector \ -mP2OPT_static_promotion \ -mP1OPT_print_version=FALSE \ -mCG_use_gas_got_workaround=F \ -mP2OPT_align_option_used=TRUE \ -mGLOB_gcc_version=421 \ "-mGLOB_options_string=-w -g -save-temps -fpic -o fout -WI,-no_pie -#" \ -mGLOB_position_independent_code \ -mGLOB_preemption_model=1 \ -mGLOB_no_compact_unwind=TRUE \ -mGLOB_cxx_limited_range=FALSE \ -mP3OPT_emit_line_numbers \ -mP2OPT_suppress_unreferenced_locals=FALSE \ -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL \ -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF20 \ -mP3OPT_dwarf_format=P3OPT_DWARF_FORMAT_OBJ_ONLY \ -mGLOB_as_output_backup_file_name=fout_as_.s \ -mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 \ -mGLOB_product_id_code=0x22006d8c \ -mGLOB_maintain_errno \ -mGLOB_noinline_intrinsics \ -mGLOB_use_base_pointer \ -mCG_bnl_movbe=T \ -mGLOB_extended_instructions=0x80 \ -mGLOB_advanced_optim=TRUE \ -mP3OPT_use_mspp_call_convention \ -mP2OPT_subs_out_of_bound=FALSE \ -mGLOB_ansi_alias \ -mIPOPT_ninl_limit=0 \ -mIPOPT_ninl_user_level=0 \ -mPGOPTI_value_profile_use=T \ -mP2OPT_gen_linux_const_pooling=FALSE \ -mP2OPT_il0_array_sections=TRUE \ -mGLOB_opt_level=0 \ -mIPOPT_args_in_regs=0 \ -mGLOB_imf_mapping_library=/usr/bin/ifort-2011-base/bin/intel64/libiml_attr.dylib \ -mIPOPT_obj_output_file_name=sps.o \ -mGLOB_long_size_64 \ -mGLOB_routine_pointer_size_64 \ -mGLOB_os_target=GLOB_OS_TARGET_MACH \ -mGLOB_async_unwind_tables=TRUE \ -mGLOB_obj_output_file=sps.o \ -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \ -mP1OPT_source_file_name=sps.f90 \ -mP2OPT_symtab_type_copy=true \ sps.f90
ld \ -lcrt1.10.6.o \ -dynamic \ -arch \ x86_64 \ -weak_reference_mismatches \ non-weak \ -macosx_version_min \ 10.7.2 \ -no_compact_unwind \ -o \ fout \ /usr/bin/ifort-2011-base/compiler/lib/for_main.o \ -L/usr/bin/ifort-2011-base/compiler/lib \ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/x86_64/ \ -L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64/ \ -L/usr/lib/ \ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/x86_64 \ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/ \ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/ \ -L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64 \ -L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/ \ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/../../../ \ -L/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/../../.. \ fout.o \ sps.o \ /usr/bin/ifort-2011-base/compiler/lib/libifport.a \ /usr/bin/ifort-2011-base/compiler/lib/libifcore.a \ /usr/bin/ifort-2011-base/compiler/lib/libimf.a \ /usr/bin/ifort-2011-base/compiler/lib/libsvml.a \ /usr/bin/ifort-2011-base/compiler/lib/libipgo.a \ -lgcc \ -lgcc_s.10.5 \ -lgcc \ -lSystem \ /usr/bin/ifort-2011-base/compiler/lib/libirc.a \ -lpthread \ -ldl
dsymutil \ fout
3) the print-out of aerr is 0. The result for "print a" are the correct values, i.e. the first 9 are 3 and the others are zero.
Jianghui
Georg_Z_Intel
Hello Jianghui,
after talking to our engineers it turned out that it's a bug in IDB. We've filed a defect ticket for it (DPD200223306). I'll let you know as soon as it is fixed.
Georg Zitzlsberger
Georg_Z_Intel
Hello Jianghui, the problem has been fixed with the initial release of Intel(R) Composer XE 2013 that is now available. Best regards, Georg Zitzlsberger
