Making DLLEXPORT functions visible from C++ DLL
ovz
I'm building a C++ DLL that links some Fortran static libraries. My environment is
Visual Studio 2012
Intel(R) Visual Fortran Compiler XE 13.1.1.171
Fortran libraries export some functions e.g.
      logical function example_function()
      !DEC$ ATTRIBUTES DLLEXPORT :: example_function
      example_function = .true.
      return
      end
When I build my C++ dll example_function does _NOT_ show up in the exports. If I add a call to this function from DllMain I get the symbol exported. What is the proper way to export Fortran functions in this configuration?
extern "C" SSSPM_EXPORT bool C_FORT_CONV example_function_();
BOOL APIENTRY DllMain( HMODULE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
Steven_L_Intel1
If it's in a library, it won't get linked in unless there's a reference. You can add the function name to Linker > Input > Force Symbol References. Maker sure it is spelled with the correct case and decoration.
Steven_L_Intel1
