Is it possible to reference Fortran runtime libraries in a VS2008 manifest in order to allow side-by-side versioning? As far as I can tell this is restricted to assemblies. Ideally I don't really want to have to install the run time in the application folder, since one of the app executables is often run from a network path. I have run the 11.1 redistributable, but need to explicitly reference the runtime directory (unfortunately I can't rely on setting PATH since I have a conflicting runtime installation elsewhere that is also included in PATH). How will 11.1 sit alongside the Fortran 12 runtime when it becomes available?
One further (related) question: are different runtime versions backwards compatible? i.e. can objects that are compiled specifically in 10.1 link with the 11.1 runtime?
