Many error occur...>help
wai88iaw
include
"link_f90_static.h"
USE
QDAWO_INT
USE
UMACH_INT
USE
CONST_INT
INTEGER
IWEIGH, NOUT
REAL
A, ABS, B, ERRABS, ERREST, ERROR, &
EXACT, F, OMEGA, PI,
RESULT
INTRINSIC
ABS
EXTERNAL
F
! Get output unit number
CALL
UMACH (2, NOUT)
! Set limits of integration
A = 0.0
B = 1.0
! Weight function = sin(10.*pi*x)
IWEIGH = 2
PI = CONST(PI)
OMEGA = 10.*PI
! Set error tolerances
ERRABS = 0.0
CALL
QDAWO (F, A, B, IWEIGH, OMEGA, RESULT, ERRABS=ERRABS, &
ERREST=ERREST)
! Print results
EXACT = -0.1281316
ERROR =
ABS(RESULT-EXACT)
WRITE
(NOUT,99999) RESULT, EXACT, ERREST, ERROR
99999
FORMAT ( Computed =, F8.3, 13X, Exact =, F8.3, /, /, &
Error estimate =, 1PE10.3, 6X, Error =, 1PE10.3)
END
REAL
FUNCTION F (X)
REAL
X
REAL
ALOG
INTRINSIC
ALOG
IF
(X .EQ. 0.) THEN
F = 0.0
ELSE
F =
ALOG(X)
END IF
RETURN
END
wai88iaw
this library has many error...but this is a library that i just copy form IMSL library, can anyone tell me what`s wrong, and what is the function of 99999
THX
wai88iaw
i can fix it when use " instead of '....but i want to know what is the function of 99999
greldak
Its just the label of the FORMAT statement refered to in the WRITE on the line above.
You don't say what the errors are.
Please read carefully the section of the Building Applications manual on IMSL, in the Using Libraries chapter. Make sure that you have added the proper IMSL INCLUDE and LIB folders to the appropriate directory lists under Tools..Options..Intel Fortran.
emc-nyc
....this library has many error?
I've used IMSL for several decades; I've never seen significant problems with it. If you're getting them, my first presumption (and it should be yours, too) is that there is something wrong with how the library is being used.
As said by Steve, you're going to have to be a bit more forthcoming with information about the nature of the errors. For example, are the errors in the compile step, the link step, or run time errors, e.g., log(x) is undefined in real numbers if x <= 0 and undefined, always, when x = 0, so trying to take log(-1) will cause a run time error.
The 99999 is just the label for the format statement.
