Since recently I get many, many "global name too long" warning, burying any other useful output from the compiler. What really confuses me is that involved names themselves are not really long. But those names are combined in a rather exuberant way and sometimes even decorated with some icing like BLK. Just one such example (instead of real names I use descriptive names):
"NameModule@NameModule_smodSomeRoutineName_mp_contained_subroutine@BLK"
Here a submodule NameModel_smod has been used, which contains subroutine SomeRoutineName. This itself has a contained subroutine which uses an associate block (probably causing the final @BLK).
Surely, if these towers of names are necessary (which I readily believe), and the compiler itself finds these names kind of indigestible (which I can easily sympathise with), there should be another way for the compiler to handle this safely and gracefully (e.g. like gits hash value technique, i.e. cryptographic hash values).
PS: I compiled with classical ifort in Linux.
連結已複製
Looks like something has gone awry then, as the many warnings only occured after I updated a couple days ago to classical version 2021.10.0 20230609. Before that, I only got such warnings rarely and then the affected names could somehow be shortened.
Here is an example with typical names (not really long) which gives such a warning (both with ifx and ifort). Unfortunately, I cannot compare this example with the previous version, as this has been replaced by the update. Compile command is just "ifort long_names.f90 -c" if the code is put into a file named "long_names.f90".
module adaptiveTimeStepSize
implicit none
private
public get_adaptiveTimeStep
interface
module subroutine get_adaptiveTimeStep()
end subroutine get_adaptiveTimeStep
end interface
end module adaptiveTimeStepSize
submodule (adaptiveTimeStepSize) adaptiveTimeStepSize_smod
implicit none
contains
call compute_upperBound()
contains
subroutine compute_upperBound()
end subroutine compute_upperBound
end submodule adaptiveTimeStepSize_smod
Thanks for the work-around, I will use it till this issue is hopefully resolved properly in a future version.
Martin, we have a fix to extend the symbol length in 2024.0. We are looking at a more full, longer-term solution but doing so could break the compiler in other places. So for 2024 your case will create a proper symbol, no warning msg. The build 24.0-1171 is a prelim build for the 2024. The edit number is sure to increase before we make our final code drop for 2024.0 verison.
ifx -what -V -c long_names.f90
Intel(R) Fortran 24.0-1171
[rwgreen@orcsle162 q05935160]$ nm long_names.o
0000000000000000 T adaptivetimestepsize._
0000000000000010 T adaptivetimestepsize.adaptivetimestepsize_smod._
0000000000000030 T adaptivetimestepsize.adaptivetimestepsize_smodget_adaptivetimestep_mp_compute_upperbound_
0000000000000020 T adaptivetimestepsize_mp_get_adaptivetimestep_
I tried to find it, but I could not find any information about the symbol length in the release notes. Has this feature been released?
Building Fortran on windows with ifx 2024.1.0 Build 20240308, it appears that symbols are truncated to 90 characters. Jim Dempsey shared a page that shows that C/C++ symbols are allowed to be 2047 characters long on Windows. Does an option exist to increase the Fortran character limit?
the symbol size in ifx and ifort is 90 characters max. There is no way to change this limit currently. It is deeply embedded in the code for ifort and ifx. This was sufficient in days before modules, submodules, and contained procedures, all of which add to the symbol length. I will ask the team to revisit this but 90 is what it is today.
The truncated symbol is usable so long as it does not conflict with another truncated symbol, which while possible is not likely. I suspect you can compile, run, debug, etc without any issues from the truncated name.
Thank you for your quick response. In that case we will probably suppress the warnings for now, and it would be great if this were addressed in a future release!
Hello, I have just upgraded to w_HPCKit_p_2023.2.0.49441. I am using the integrated version with visual studio 2022 Version 17.7.0.
When I use “ /Qdiag-disable:5462” I get the following errors:
Compiling with Intel® Fortran Compiler Classic 2021.10.0 [Intel(R) 64]..
myfile.f90
myfile.f90(2770): error #5462: Global name too long, shortened from:
MYMMODULENAME11111111111111111_MP_MYSUBROUTINEVERYLONGNAME11111111111111111111111111
TO
MYMMODULENAME111111111111_MP_MYSUBROUTINEVERYLONGNAME11111111111111111111111111
Cannot disable Fortran error message 5462
ifort: error #10298: problem during post processing of parallel object compilation
compilation aborted for myfile.f90 (code 1)
What could I do ?
Thank you
You could shorten the module and procedure names. As Ron Green says in a post above yours, a solution for this problem is coming in a future release. The fundamental problem is that the Microsoft object file format and linker limit global symbol names to 63 characters.
You don't have to DO anything - the compiler did it for you. I had thought the limit was 63 characters, maybe it's a bit more. In any case, you can ignore the warning for now (but can't disable it.)
