Memory Space Issue?
pfwang
I was able to compile and run a fortran code, which required a large memory space. After the compiled code started execution for some time, the code crashed. The following messages showed up on the debug screen:
Loaded 'ntdll.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32kernel32.dll', no matching symbolic information found.
Loaded 'C:PFWorkingSDBCH3DCH3D-SDBCH3D-SDBDebug etcdf.dll', no matching symbolic information found.
The thread 0xF64 has exited with code 0 (0x0).
The program 'C:PFWorkingSDBCH3DCH3D-SDBCH3D-SDBDebugjame_ch3d_transp_sinclair_FC_netCDF.exe' has exited with code 0
Can anyone provide any help on this? What doesthis mean? Thanks.
pfwang
I was supplied a code, which contains multiple .for files with some .inc (include files). I also found a UTILIO.ASM file (which may be for utility for input/output). This UTILIO.ASM looks like a source file, but does not look like fortran file. It seems to control the input/output withoperations on screens (erase screen, ... ) Do you have any idea what this file is? How do I compile it into the executable? Thanks...
Could be assembler. Can you post an excerpt? If it is assembler, you need to get Microsoft MASM which is a free download for Visual Studio users. You'll need to be sure that the assembler routine follows the expected calling convention of the code that calls it.
pfwang
Thanks, yes I think it is an assembler. I have downloaded Microsoft MSAM. How do I compiles the .for files with the assembler file? My previous experience with DVF has involved only with .for and .inc files.
You use MASM to create .obj files and then link those with your Fortran-compiled .obj files. Believe it or not, there is information about mixed MASM-Fortran applications in the DVF/CVF Programmer's Guide (and the IVF Building Applications manual.)
grg99
Hmmmm, there may be a problem. Usually when there is assembly language to clear the screen, that code was intended to run under the old MSDOS. Are there calls to "int 21h" or "int 10h" ? Those are the old obsolete ways of clearing the text screen in MSDOS. They only work if called from 16-bit ral mode code.
Those calls will NOT work with most modern compilers that generate 32 pr 64-bit protected mode code.
You may just want to write Fortran replacements for those routines, which at first just do
Print *, ""
eventually when the rest of the program is running okay you can go back and patch in the correct modern ways of clearing the screen, burping the baby, etc, etc..
farrow22
Steve,
for 64-bit development on 64-bit Windows, do you still recommend VS.NET 2003 over VS2005?
Thanks, Roger
No, for 64-bit, VS2005 is really the only option as that gives you debugging and VS building for 64-bit, which VS2003 does not.
