Memory leak with structure constructors
IanH
With 13.0.1 (and earlier...) I've got an issue with a memory leak using allocatables that I strongly suspect is due to erroneous handling of INTENT(OUT) arguments of derived type with allocatable polymorphic components.  I thought I had a reproducer, but relevant to my circumstances, but some recent mods to that reproducer now make me think that the problem is with structure constructors.
[fortran]MODULE m20121031
  IMPLICIT NONE
  PRIVATE
  ! Our bug demonstration/workaround option.  This was just a sequence number,
  ! but then we started to get fancy, then we started to get confused.
  ! Bit 0 - false for non-polymorphic container,
  !         true for polymorphic
  ! Bit 1 - false for CopyA (INTENT(OUT) dummy),
  !         true for CopyB (INOUT).
  ! Bit 2 - false for init using SOURCE=structure constructor,
  !         true for ye-olde 11.x or whatever bug workaround.
  ! Bit 3 - false for non-polymorphic dummy in Copy*.
  !       - true for polymorphic dummy in Copy*.
  INTEGER, PUBLIC :: option
  INTEGER, PUBLIC, PARAMETER :: bit_polycontainer = 0
  INTEGER, PUBLIC, PARAMETER :: bit_inout = 1
  INTEGER, PUBLIC, PARAMETER :: bit_strcons = 2
  INTEGER, PUBLIC, PARAMETER :: bit_polydummy = 3
  PUBLIC :: Init
  PUBLIC :: CopyOut
  PUBLIC :: CopyOutP
  PUBLIC :: CopyInOut
  PUBLIC :: CopyInOutP
  TYPE, PUBLIC :: Parent
  END TYPE Parent
  TYPE, PUBLIC :: Container
    CLASS(Parent), ALLOCATABLE :: item
  END TYPE Container
  TYPE, PUBLIC, EXTENDS(Parent) :: Extension
    INTEGER, ALLOCATABLE :: large(:)
  END TYPE Extension
CONTAINS
  ! Allocate an object for each item in the container array.
  SUBROUTINE Init(c)
    TYPE(Container), INTENT(OUT) :: c(:)
    INTEGER :: i
    DO i = 1, SIZE(c)
      ! Set each item to be an Extension object, with an array that requires
      ! 400 kB or so, assuming four bytes per array element.
      IF (BTEST(option, bit_strcons)) THEN
        ! The following makes ifort 13.0.1 babble "error #6593: The number of
        ! expressions in a structure constructor differs from the number of
        ! components of the derived type."
        ! ALLOCATE(c(i)%item, SOURCE=Extension(SPREAD(0.0, 1, 100*1000)))
        ! So lets do...
        ALLOCATE(c(i)%item, SOURCE=Extension(LARGE=SPREAD(0.0, 1, 100*1000)))
        ! The above seems to be the source of evil?  How???  It's only called
        ! "once", and I'm pretty sure this shortcut wasn't part of my initial
        ! testing.
      ELSE
        ! This is what we used to (still?) do...
        ALLOCATE(Extension :: c(i)%item)
        SELECT TYPE (item => c(i)%item)
        TYPE IS (Extension)
          ALLOCATE(item%large(100*1000))
        END SELECT
        ! but this branch doesn't seem to leak now.
      END IF
    END DO
  END SUBROUTINE init
  ! The straight forward approach - INTENT(OUT) argument "should" result
  ! in deallocation of the contents of `to` when this routine is called.
  SUBROUTINE CopyOut(from, to)
    TYPE(Container), INTENT(IN) :: from(:)
    TYPE(Container), INTENT(OUT) :: to(:)
    INTEGER :: i
    DO i = 1, SIZE(from)
      ALLOCATE(to(i)%item, SOURCE=from(i)%item)
    END DO
  END SUBROUTINE CopyOut
  ! INTENT(OUT), polymorphic dummy argument.
  SUBROUTINE CopyOutP(from, to)
    CLASS(Container), INTENT(IN) :: from(:)
    CLASS(Container), INTENT(OUT) :: to(:)
    INTEGER :: i
    END DO
  END SUBROUTINE CopyOutP
  ! Let us do some of the compilers work for it.
  SUBROUTINE CopyInOut(from, to)
    TYPE(Container), INTENT(INOUT) :: to(:)
    INTEGER :: i
      ! In larger examples we seen the ALLOCATED test returning true and
      ! then the deallocate failing because the object wasn't allocated???
      IF (ALLOCATED(to(i)%item)) DEALLOCATE(to(i)%item)
    END DO
  END SUBROUTINE CopyInOut
  ! Let us do some of the compilers work for it, polymorphic dummy.
  SUBROUTINE CopyInOutP(from, to)
    CLASS(Container), INTENT(INOUT) :: to(:)
    INTEGER :: i
    END DO
  END SUBROUTINE CopyInOutP
END MODULE m20121031
PROGRAM Leak
  USE m20121031
  IMPLICIT NONE
  ! Container size.  Just needs to be big enough such that (when combined
  ! with the size of an individual item in the container) memory
  ! leakage becomes bleedingly obvious.
  INTEGER, PARAMETER :: container_size = 20
  ! Odd options use the non-polymorphic pair, even options use the
  ! polymorphic pair.
  TYPE(Container), ALLOCATABLE :: ta(:), tb(:)
  CLASS(Container), ALLOCATABLE :: ca(:), cb(:)
  INTEGER :: i                ! Container index.
  CHARACTER(4) :: arg         ! Command line argument.
  ! Get the workaround option.
  IF (COMMAND_ARGUMENT_COUNT() == 0) THEN
    PRINT "(A)", 'First command line argument specifies the test option as a &
        &bit string.'
    PRINT "(A)", 'For a string dcba:'
    PRINT "(A)", '  - d: 0 for non-polymorphic dummy in Copy*.'
    PRINT "(A)", '       1 for polymorphic dummy in Copy*.'
    PRINT "(A)", '  - c: 0 for ye-olde work around init.'
    PRINT "(A)", '       1 for structure constructor init.'
    PRINT "(A)", '  - b: 0 for INTENT(OUT) dummy.'
    PRINT "(A)", '       1 for INTENT(INOUT) dummy.'
    PRINT "(A)", '  - a: 0 for non-polymorphic container.'
    PRINT "(A)", '       1 for polymorphic container.'
    STOP
  END IF
  CALL GET_COMMAND_ARGUMENT(1,arg)
  READ (arg,"(B4)") option
  PRINT "('option is ',B4.4)", option
  ! Some setup.
  ! 20 items in the array means that we need about 8 MB.
  IF (BTEST(option, bit_polycontainer)) THEN
    ALLOCATE(ca(container_size), cb(container_size))
    CALL init(ca)
  ELSE
    ALLOCATE(ta(container_size), tb(container_size))
    CALL init(ta)
  END IF
  ! Our leaky loop.
  ! If we leak 8 MB each iteration, then one thousand iterations comfortably
  ! blows virtual address space on my pathetic little laptop.
  DO i = 1, 1000
    IF (MOD(i, 10) == 0) PRINT *, i
    IF (BTEST(option, bit_polydummy)) THEN
      IF (BTEST(option, bit_inout)) THEN
          CALL CopyInOutP(ca, cb)
        ELSE
          CALL CopyInOutP(ta, tb)
        END IF
      ELSE
          CALL CopyOutP(ca, cb)
        ELSE
          CALL CopyOutP(ta, tb)
        END IF
      END IF
    ELSE
          CALL CopyInOut(ca, cb)
        ELSE
          CALL CopyInOut(ta, tb)
        END IF
      ELSE
          CALL CopyOut(ca, cb)
        ELSE
          CALL CopyOut(ta, tb)
        END IF
      END IF
    END IF
  END DO
END PROGRAM Leak[/fortran]
Build....
[plain]>ifort /check:all /warn:all /standard-semantics /Od /traceback /stand:f03 "20121031 leak.f90"
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 13.0.1.119 Build 20121008
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation.  All rights reserved.
"-out:20121031 leak.exe"
-subsystem:console
-incremental:no
"20121031 leak.obj"[/plain]
Any option where structure constructors are used (now) seems to trigger the leak, i.e. run with any command line argument that has a bit pattern like "x1xx".
[plain]>"20121031 leak.exe" 0100
option is 0100
 10
 20
 30
 40
 50
 60
 70
 80
 90
 100
 110
 120
 130
 140
 150
 160
 170
 180
 190
 200
 210
 220
 230
 240
 250
 260
forrtl: severe (41): insufficient virtual memory[/plain]
The speed of execution of the non-structure constructor options "x0xx" makes me wonder whether the leak test is real, but I've not yet looked at the disassembly.
This is a problem I really need to resolve, but a quick review indicates that structure constructors are probably the cause of the issue for me - as I don't seem to use them in the full code.  It may be that I need another level of component-ness before the problem manifests, or perhaps my testing above has gone astray.  Anyway, something still ain't right with INTENT(OUT) and polymorphic things.
IanH
Got him, sort of. Perhaps I was unfairly blaming maligning structure constructors and this is just a general case of the compiler whacking things it shouldn't. Consider: [fortran]MODULE m20121031c IMPLICIT NONE PRIVATE PUBLIC :: Init PUBLIC :: CopyOutA TYPE, PUBLIC :: Parent END TYPE Parent TYPE, PUBLIC :: Container CLASS(Parent), ALLOCATABLE :: item END TYPE Container TYPE, PUBLIC, EXTENDS(Parent) :: Extension INTEGER, ALLOCATABLE :: large(:) END TYPE Extension CONTAINS ! Allocate an object for each item in the container array. SUBROUTINE Init(c) TYPE(Container), INTENT(OUT) :: c(:) INTEGER :: i !*************************************************************************** DO i = 1, SIZE(c) ! Set each item to be an Extension object, with an array that requires ! 400 kB or so, assuming four bytes per array element. ALLOCATE(Extension :: c(i)%item) SELECT TYPE (item => c(i)%item) TYPE IS (Extension) ALLOCATE(item%large(100*1000)) END SELECT END DO END SUBROUTINE Init ! The straight forward approach - INTENT(OUT) argument "should" result in ! deallocation of `to` and the contents of `to` when this routine is called. SUBROUTINE CopyOutA(from, to) TYPE(Container), INTENT(IN) :: from(:) TYPE(Container), INTENT(OUT), ALLOCATABLE :: to(:) INTEGER :: i !*************************************************************************** ALLOCATE(to(SIZE(from))) DO i = 1, SIZE(from) ALLOCATE(to(i)%item, SOURCE=from(i)%item) END DO END SUBROUTINE CopyOutA END MODULE m20121031c PROGRAM Leak USE m20121031c IMPLICIT NONE ! Container size. Just needs to be big enough such that (when combined ! with the size of an individual item in the container) memory ! leakage becomes bleedingly obvious. INTEGER, PARAMETER :: container_size = 20 ! Our containers. TYPE(Container), ALLOCATABLE :: ta(:), tb(:) INTEGER :: i ! Iteration index. !***************************************************************************** !----------------------------------------------------------------------------- ! Some setup. ! 20 items in the array means that we need about 8 MB. ALLOCATE(ta(container_size)) CALL init(ta) !----------------------------------------------------------------------------- ! Our leaky loop. ! If we leak 8 MB each iteration, then one thousand iterations comfortably ! blows virtual address space on my pathetic little laptop. DO i = 1, 1000 IF (MOD(i, 10) == 0) PRINT *, i CALL CopyOutA(ta, tb) END DO END PROGRAM Leak[/fortran] Build him... [plain]>ifort /check:all /warn:all /standard-semantics /Od /traceback /stand:f03 "20121031c leak.f90" Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 13.0.1.119 Build 20121008 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. Microsoft (R) Incremental Linker Version 10.00.40219.01 Copyright (C) Microsoft Corporation. All rights reserved. "-out:20121031c leak.exe" -subsystem:console -incremental:no "20121031c leak.obj"[/plain] and run him... [plain]>"20121031c leak.exe" 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 160 170 180 190 200 210 220 230 240 250 260 forrtl: severe (41): insufficient virtual memory Stack trace terminated abnormally.[/plain] But when we tried to get clever, he changed his colours... [fortran]MODULE m20121031b IMPLICIT NONE PRIVATE PUBLIC :: Init PUBLIC :: CopyOutA PUBLIC :: CopyOutAP TYPE, PUBLIC :: Parent END TYPE Parent TYPE, PUBLIC :: Container CLASS(Parent), ALLOCATABLE :: item END TYPE Container TYPE, PUBLIC, EXTENDS(Parent) :: Extension INTEGER, ALLOCATABLE :: large(:) END TYPE Extension CONTAINS ! Allocate an object for each item in the container array. SUBROUTINE Init(c) TYPE(Container), INTENT(OUT) :: c(:) INTEGER :: i !*************************************************************************** DO i = 1, SIZE(c) ! Set each item to be an Extension object, with an array that requires ! 400 kB or so, assuming four bytes per array element. ALLOCATE(Extension :: c(i)%item) SELECT TYPE (item => c(i)%item) TYPE IS (Extension) ALLOCATE(item%large(100*1000)) END SELECT END DO END SUBROUTINE Init ! The straight forward approach - INTENT(OUT) argument "should" result in ! deallocation of `to` and the contents of `to` when this routine is called. SUBROUTINE CopyOutA(from, to) TYPE(Container), INTENT(IN) :: from(:) TYPE(Container), INTENT(OUT), ALLOCATABLE :: to(:) INTEGER :: i !*************************************************************************** ALLOCATE(to(SIZE(from))) DO i = 1, SIZE(from) ALLOCATE(to(i)%item, SOURCE=from(i)%item) END DO END SUBROUTINE CopyOutA ! Polymorphic to. SUBROUTINE CopyOutAP(from, to) TYPE(Container), INTENT(IN) :: from(:) CLASS(Container), INTENT(OUT), ALLOCATABLE :: to(:) INTEGER :: i !*************************************************************************** ALLOCATE(to(SIZE(from))) DO i = 1, SIZE(from) ALLOCATE(to(i)%item, SOURCE=from(i)%item) END DO END SUBROUTINE CopyOutAP END MODULE m20121031b PROGRAM Leak USE m20121031b IMPLICIT NONE ! Container size. Just needs to be big enough such that (when combined ! with the size of an individual item in the container) memory ! leakage becomes bleedingly obvious. INTEGER, PARAMETER :: container_size = 20 ! Our containers. TYPE(Container), ALLOCATABLE :: ta(:), tb(:) CLASS(Container), ALLOCATABLE :: ca(:), cb(:) INTEGER :: i ! Iteration index. CHARACTER(2) :: arg ! Command line argument. ! Our bug demonstration/workaround option. ! ! Bit 0 - false for non-polymorphic container, ! true for polymorphic. ! Bit 1 - false to assume compiler will do its job, ! true to do the compilers job manually. INTEGER :: option !***************************************************************************** !----------------------------------------------------------------------------- ! Get the workaround option. IF (COMMAND_ARGUMENT_COUNT() == 0) THEN PRINT "(A)", 'First command line argument specifies the test option as a & &bit string.' PRINT "(A)", 'For a string dcba:' PRINT "(A)", ' - b: 0 to assume INTENT(OUT) for allocatables works.' PRINT "(A)", ' 1 to deallocate before INTENT(OUT).' PRINT "(A)", ' - a: 0 for non-polymorphic container.' PRINT "(A)", ' 1 for polymorphic container.' STOP END IF CALL GET_COMMAND_ARGUMENT(1,arg) READ (arg,"(B2)") option PRINT "('option is ',B2.2)", option !----------------------------------------------------------------------------- ! Some setup. ! 20 items in the array means that we need about 8 MB. Note that we ! allocate both a and b - so the deallocate's below always have something ! allocated to work with. IF (BTEST(option, 0)) THEN ALLOCATE(ta(container_size), tb(container_size)) CALL init(ta) ELSE ALLOCATE(ca(container_size), cb(container_size)) CALL init(ca) END IF !----------------------------------------------------------------------------- ! Our leaky loop. ! If we leak 8 MB each iteration, then one thousand iterations comfortably ! blows virtual address space on my pathetic little laptop. DO i = 1, 1000 IF (MOD(i, 10) == 0) PRINT *, i SELECT CASE (option) CASE (INT(B'00')) ; CALL CopyOutA(ta, tb) CASE (INT(B'01')) ; CALL CopyOutAP(ca, cb) CASE (INT(B'10')) ; DEALLOCATE(tb) ; CALL CopyOutA(ta, tb) CASE (INT(B'11')) ; DEALLOCATE(cb) ; CALL CopyOutAP(ca, cb) CASE DEFAULT ; STOP 'You can''t count!' END SELECT END DO END PROGRAM Leak[/fortran] Build as for previous. Options 00 (which should be equivalent to the above) and 01 work, but 10 and 11 fail with a bogus "trying to deallocate something not allocated". Random compiler memory rampages worry me somewhat (perhaps my workarounds aren't workarounds, what else gets broken etc), so any discussion about what's causing the apparent corruption appreciated.
Steven_L_Intel1
Thanks - I'll take a look at this.
Steven_L_Intel1
I have escalated the one with the "insufficient virtual memory" as DPD200238121. My analysis suggests that it is not deallocating the "item" components properly when the INTENT(OUT) is processed. It is trying to deallocate each element of "to" but not getting it right - I think. I have not yet looked at the second example but will do so next week.
Steven_L_Intel1
The initial problem, and I am pretty sure the second one as well, will be fixed in a release later this year. I'll verify that both programs work with the new release.
IanH
Any hints as to the timing of this release?
Steven_L_Intel1
When did we release the last major version?
