Memory probelm
Emiliano_Cancellieri
I'm running a code using the intel fortran compiler 11.1 and the FFT of the mkl that come with the same compiler. The code is perfectly working when I'm running codes using small amount of memory but gives segmentation fault when I'm trying to use bigger arrays.
I've tryied the -mcmode medium and large option while compiling but I still have the same problem. It is not a problem of few amount of ram since the same code can run on another
machine with older verions of the compiler and and mkl and with smaller amount of ram.
Any advise?
thanks
emiliano
Ron_Green
Try this article:
http://software.intel.com/en-us/articles/determining-root-cause-of-sigsegv-or-sigbus-errors/
which is listed in the articles at the top of this forum.
ron
Perfectly working,
thanks
emiliano
