29376 Discussions
IMSL (Windows) troubles - is this the right forum?
chris-sn
Is this the right place to seek help on linking in IMSL functions, if not can someone point me in the right direction?
Thanks!
Ok. You have (perhaps understandably) missed the section of our documentation on using IMSL - this is under Building Applications > Using Libraries > Using the IMSL libraries.
Instead of naming individual libraries in the link line, the recommended method is to add a line as follows to one of your sources:
INCLUDE 'link_fnl_static.h'
If you have not also enabled OpenMP (which the IMSL documentation recommends), then add the following line as well:
!DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
It is this latter that will resolve the __kmpc symbols.
Since you are using LINEAR_OPERATORS, I will also comment that if you decide to build a 64-bit application, please read this article to get replacement modules. 32-bit doesn't need this.
Yes, it is, if you are using the IMSL from Intel Visual Fortran. I suggest you read this first to see if it helps.
chris-sn
OK, thanks, I did indeed the article suggested and have (I hope) followed its instructions.
In case it's relevant, we are dealing here with a recently-converted CVF project pair in which a FORTRAN computational engine using IMSL is linked as a static library and used by a thin C++ wrapper linked as a dll.
It turns out that in this project the only use of IMSL is in a couple of FORTRAN lines of the form
ABCD=QA.ix.F
Which could easily be rewritten, but we want to use IMSL in a different project so we persevered...
Based on an article we found we replaced the old USE IMSL with USE LINEAR_OPERATORS
We then got through compilation but the dll link failed with
error LNK2019: unresolved external symbol _OPERATION_IX_mp_DIMDVP
We eventually discovered the libs in Program Files\VNI\imsl\fnl600\IA32\lib and by trial and error chucked imsl.lib and imsl_dll.lib in as additional dependencies to the Linker input. This moved us on and now we get
1>imsl.lib(operation_ix.obj) : error LNK2019: unresolved external symbol ___kmpc_global_thread_num referenced in function _OPERATION_IX_mp_ZIBZBP
1>imsl.lib(operation_ix.obj) : error LNK2019: unresolved external symbol ___kmpc_threadprivate_cached referenced in function _OPERATION_IX_mp_ZIBZBP
At this point I start to run out ofideas, plus I get a growing feeling that it shouldn't be this hard and I am going about it the wrong way... :-(
chris-sn
Thanks again Steve - that has sorted it.
I meant to add, I am also getting these warning messages :
2>tm_calc_lib.lib(INGPLC.obj) : warning LNK4049: locally defined symbol _MPIPRIV1 imported
2>tm_calc_lib.lib(INGPLC.obj) : warning LNK4049: locally defined symbol _MPIPRIV2 imported
2>tm_calc_lib.lib(INGPLC.obj) : warning LNK4049: locally defined symbol _MPIPRIVC imported
where INGPLC.OBJ is the compiled version of the fortran file which calls IMSL.
Do you recognise these - I don't have any matches for MPIPRIV in my source code. Don't know yet if it is going to cause trouble...
You can ignore those warnings - they won't cause any problems. The symbols come from IMSL.
