Memory
JohnNichols
Honored Contributor I
Back in the old days - Conte and deBoore was a nice textbook on Numerical Analysis. I remember using this textbook in my Mechanical Engineering course on Numerical Analysis - of course one could only use Fortran then.
Skip forward to 1987 and I needed a quick inverter to solve a minor problem, so I used the old Conte and de Boore method.
I still have the code and the examples.
The structural analysis package I lifted from 1973 is giving me one or two minor and interesting answers that I wanted to check - nothing major just annoyances as I work out the program.  Combined with FEAST it is a treat to use compared to a commerical package, one can get at all the numbers quickly and can play with them.
So I thought I would run out the old program,  found the floppy drive, load it into VS 2013 - compiles first time - run out a 30 by 30 test case from the 73 code and get the C and deB to invert the matrix, to see if the results are the same.
Answer was a big NO.
Load up the C and deBoore test case, one can still find a PDF of the textbook online -- must be illegal - but what the heck. Still getting the wrong answer on reading in the data.  After a bit of exploration with Watch on VS 2013, I learnt something I had completely forgotten, one can pass a vector through a subroutine call and then declare it as an array in the subroutine. Here was the sticking point - it is in column and not row order.   Fixing the input routines solved a simple problem and now I can check the 73 code.  Of course one should load up the MKL inverter, but what the heck life is short play hard.  I need to put the MKL inverter into the 73 code, that is next.
One of the problems with eigenvectors is visuallying the result.  I have DISLIN - but I was darned if I could get it to run at the weekend - just ornery I guess and a 9 year old yellling in my ear, I had a simple bitmap drawer from Japan, so I thought - what the heck it is only simple line sketches.  I thought I need to draw lines, circles and some text.  I was fun -- text looks like MS DOS prompts after heated to 1200 C, but who cares.  It is possible to create bitmaps from a standard FORTRAN program -- of course it is not pretty - but then again neither am I.
Here is the code - very old Fortran - but it still works. and is often said - if it is not broken do not fix it
C *********************************************************************
      PROGRAM MATRIX
C      This is a matrix inversion progamme taken from Conte and deBoor
C      Elementary Numerical Analysis.
C      It has been amended to run on an IBM PC under Microsoft Fortran
C      by John Nichols.
      implicit character*60(z)
      DIMENSION Aorg(10000)
      Dimension A(10000),ainv(10000),b(100),ipivot(100),c(100),d(100)
      write(*,1)
1     format(1x,'This is an IBM MICROSOFT FORTRAN programme',/
     11x,'from CONTE and de BOOR,amended by John Nichols',/
     21x,'in July 1987.',/
     31x,' Ver. 1.0 --Ph (049 25464).'//)
C
C
C      Read input and output devices for files.
C
C
      write(*,20)
20    format(1x,'File name for input data :   '\)
      read(*,30)zFILE1
30    format(a12)
      write(*,40)
40    format(1x,'File name for output data :   '\)
      read(*,50)zFILE2
50    format(a12)
C
C
C      Open files for input ouput
C
C
      write(*,60)
60    format(1x,'Opening the input file to access data!'/)
      open(1,file=zFILE1,status='OLD')
      write(*,70)
70    format(1x,'Opening the output file for data!'/)
      open(2,file=zFILE2,status='UNKNOWN')
C
C
C      Read input data from file 1
C
C
100   continue
      c(1:100)=0.0
      read(1,80)N
80    format(I3)
      write(*,90)N
90    format(1x,'The matrix size is ',i2/)
      read(1,*)(d(j),j=1,n)
      read(1,*)N1
      nsq=N*N
      read(1,*)(a(j),j=1,nsq)
      do 102 i = 1,nsq
          aorg(i) = a(i)
102   end do
      write(*,101)(a(j),j=1,nsq)
  101 format(3(2x,F10.6))
      write(*,101)(d(j),j=1,n)
C
C
C      Call factor subroutine
C
C
      write(*,150)
150   format(1x,'At the factor subroutine!',/)
      call factor(a,a,ipivot,b,n,iflag)
      go to (120,110),iflag
110   continue
C
C
C      The matrix is singular
C
C
      write(*,130)
130   format(1x,'This matrix is singular have another shot!',/)
      go to 210
120   continue
C
C
C      Call subst subroutine
C
C
      do 140 I=1,N
          b(i)=0.0
140   continue
      ibeg=1
      do  160 j=1,N
          b(j)=1.0
          call subst(a,b,ainv(ibeg),ipivot,n)
          b(j)=0.0
          ibeg=ibeg+N
160   continue
C
C
C      Inverted matrix results
C
C
      write(2,170)
      write(*,170)
170   format(1x,'The computed inverse is ',//)
      write(2,101)(ainv(j),j=1,nsq)
      write(*,101)(ainv(j),j=1,nsq)
180   format((3F10.5))
210   continue
      call MatrixResult(aorg, ainv,d,c,n)
C
C
C      End of programme
C
C
      write(*,200)
200   format(1x,'The end of the programme',/)
      end
C
C
      Subroutine MatrixResult(a,ainv,d,c, n)
C
C
      dimension a(n,n),d(n),c(n),ainv(n,n), f(n,n)
      integer n,i,j
      do 100 i = 1,n
          do 200 j =1,n
              c(i) = a(i,j)*d(i)+c(i)
200       Continue
100   Continue
      f(1:n,1:n)=0.0
      do 400 i=1, n
          do 300 j=1, n
              do 250 k=1, n
                  f(i,j)=f(i,j)+a(j,k)*ainv(k,i)
250   enddo
300   end do
400   end do
      do 500 i = 1,n
          write(*,180)(F(i,j),j=1,n)
500   end do
180   format((30F4.1))
      write(*,70)
70    format(1x,'Opening the C  data!'/)
      write(*,*)(c(i),i=1,n)
      return
      end
C
C
C
      Subroutine Factor(a,w,ipivot,d,n,iflag)
C
C
      dimension a(n,n),w(n,n),ipivot(n),d(n)
C
C
C      initialize vectors
C
C
      iflag=1
      do 10 i=1,n
          ipivot(i)=i
          rowmax=0.0
          do 20 j=1,n
              w(i,j)=a(i,j)
              rowmax=amax1(rowmax,abs(w(i,j)))
20        continue
          if(rowmax .eq. 0.0) go to 999
          d(i)=rowmax
10    continue
C
C
C      Gaussian elimination with scaled partial pivotting
C
C
      nm1=n-1
      if(nm1 .eq. 0) return
      do 30 k=1,nm1
          j=k
          kp1=k+1
          ip=ipivot(k)
          colmax=abs(w(ip,k))/d(ip)
          do 40 i=kp1,n
              ip=ipivot(i)
              awikov=abs(w(ip,k))/d(ip)
              if (awikov .le. colmax ) go to 40
              colmax=awikov
              j=i
40        continue
          if (colmax .eq. 0.0) go to 999
          ipk=ipivot(j)
          ipivot(j)=ipivot(k)
          ipivot(k)=ipk
          do 30 i=kp1,n
              ip=ipivot(i)
              w(ip,k)=w(ip,k)/w(ipk,k)
              ratio=-w(ip,k)
              do 30 j=kp1,n
                  w(ip,j)=ratio*w(ipk,j)+w(ip,j)
30    continue
      if (w(ip,n) .eq. 0.0) go to 999
      return
999   iflag=2
      return
      end
C
C
      subroutine subst (w,b,x,ipivot,n)
C
C
      dimension w(n,n),b(n),x(n),ipivot(n)
      if (n .gt. 1) go to 10
      x(1)=b(1)/w(1,1)
      return
10    continue
      ip=ipivot(1)
      x(1)=b(ip)
      do 15 k=2,n
          ip=ipivot(k)
          km1=k-1
          sum=0.0
          do 14 j=1,km1
              sum=w(ip,j)*x(j)+sum
14        continue
          x(k)=b(ip)-sum
15    continue
      x(n)=x(n)/w(ip,n)
      k=n
      do 20 np1mk=2,n
          kp1=k
          k=k-1
          ip=ipivot(k)
          sum=0.0
          do 19 j=kp1,n
19        continue
          x(k)=(x(k)-sum)/w(ip,k)
20    continue
      return
      end
