Mexopts / Mex Function Editing
postaquestion
I'm having a problem running the mex function in Matlab 7.3.0.267 (R2006b) 64-bit with the Intel Visual Fortran Compiler 10.0 for Windows. Could you perhapse provide me with information how I can modify the mexopts file?
Thanks in advance.
I think we need some more information. What exactly is the problem you are having? What does your current mexopts file look like?
christoph_bauer
The mexopts file looks like this:
@echo off
rem INTELF10OPTS.BAT
rem
rem Compile and link options used for building MEX-files
rem using the Intel Fortran Cmpiler, Version 9.0
rem
rem $Revision: 1.1.6.4 $ $Date: 2006/06/23 19:04:58 $
rem
rem ********************************************************************
rem General parameters
set MATLAB=%MATLAB%
set IFORT_COMPILER90=%IFORT_COMPILER90%
set LINKERDIR=%MSSdk%
set PATH=%IFORT_COMPILER90%EM64TBin;%LINKERDIR%BinWin64x86AMD64;%LINKERDIR%Bin;%LINKERDIR%BinWinNT;%PATH%
set INCLUDE=%IFORT_COMPILER90%EM64TInclude;%LINKERDIR%Include;%LINKERDIR%Includecrt;%LINKERDIR%Includecrtsys;%LINKERDIR%Includemfc;%LINKERDIR%Includeatl;%INCLUDE%
set LIB=%IFORT_COMPILER90%EM64TLib;%LINKERDIR%LibAMD64;%LINKERDIR%LibAMD64atlmfc;%LIB%
set MW_TARGET_ARCH=win64
rem Compiler parameters
set COMPILER=ifort
set COMPFLAGS=/fpp /Qprec "/I%MATLAB%/extern/include" -c -nologo -DMATLAB_MEX_FILE /fixed
set OPTIMFLAGS=/MD -Ox -DNDEBUG
set DEBUGFLAGS=/MD -Zi
set NAME_OBJECT=/Fo
rem Linker parameters
set LIBLOC=%MATLAB%externlibwin64microsoft
set LINKER=link
set LINKFLAGS=/DLL /EXPORT:MEXFUNCTION /MAP /LIBPATH:"%LIBLOC%" libmx.lib libmex.lib libmat.lib /implib:%LIB_NAME%.lib /NOLOGO
set LINKOPTIMFLAGS=
set LINKDEBUGFLAGS=/debug
set LINK_FILE=
set LINK_LIB=
set NAME_OUTPUT="/out:%OUTDIR%%MEX_NAME%.mexw64"
set RSP_FILE_INDICATOR=@
rem Resource compiler parameters
set RC_COMPILER=rc /fo "%OUTDIR%mexversion.res"
set RC_LINKER=
set POSTLINK_CMDS=del "%OUTDIR%%MEX_NAME%.map"
and I am getting this report
--> "ifort /fpp /Qprec "/IC:PROGRA~3MATLABR2006b/extern/include" -c -nologo -DMATLAB_MEX_FILE /fixed /FoC:DOCUME~1auer2LOCALS~1Tempmex_3E5D61C5-0C37-40D5-58AB-213FD0F36DA8yprimefg.obj /MD -Ox -DNDEBUG -DMX_COMPAT_32 yprimefg.f"
Contents of C:DOCUME~1auer2LOCALS~1Tempmex_3E5D61C5-0C37-40D5-58AB-213FD0F36DA8mex_tmp.rsp:
--> "link "/out:yprimefg.mexw64" /DLL /EXPORT:MEXFUNCTION /MAP /LIBPATH:"C:PROGRA~3MATLABR2006bexternlibwin64microsoft" libmx.lib libmex.lib libmat.lib /implib:C:DOCUME~1auer2LOCALS~1Tempmex_3E5D61C5-0C37-40D5-58AB-213FD0F36DA8 emplib.lib /NOLOGO @C:DOCUME~1auer2LOCALS~1Tempmex_3E5D61C5-0C37-40D5-58AB-213FD0F36DA8mex_tmp.rsp "
Der Befehl "link" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
&n bsp; C:PROGRA~3MATLABR2006BBINMEX.PL: Error: Link of 'yprimefg.mexw64' failed.
If I am translating the German correctly, it is saying that it cannot find "link", probably because the path to it is not set up correctly.
I see:
Is the MSSdk environment variable defined?
christoph_bauer
You are right, it can not find the linker, but now i have modified the envirioment variable, because there is the xilink linker with fortran, but then it says
xilink: executing 'link'
Usually there is some other message preceding that one that indicates the real error.
christoph_bauer
There is no other message:
--> "ifort /fpp /Qprec "/IC:PROGRA~3MATLABR2006b/extern/include" -c -nologo -DMATLAB_MEX_FILE /fixed /FoC:DOCUME~1auer2LOCALS~1Tempmex_66E4E064-95F3-473D-4291-1FAE70BF1924yprimefg.obj /MD -Ox -DNDEBUG -DMX_COMPAT_32 yprimefg.f"
Contents of C:DOCUME~1auer2LOCALS~1Tempmex_66E4E064-95F3-473D-4291-1FAE70BF1924mex_tmp.rsp:
--> "xilink "/out:yprimefg.mexw64" libmx.lib @C:DOCUME~1auer2LOCALS~1Tempmex_66E4E064-95F3-473D-4291-1FAE70BF1924mex_tmp.rsp "
I would try to repeat the xilink command with the .rsp file, from a command prompt. It seems that something is being hidden from you.
Personally, I would recommend against using xilink as the link command. Use ifort to link instead.
