Migrating from G77 to IFC
Intel_C_Intel
Hello!
Until now I have been using the G77 compiler with the CERNlib libraries, and now I would like to test the ifort compiler performance. Is there a way to use those libraries (compiled for gcc) directly with ifc?
Directly including them with -lfoo fails in the linking phase, but it does resolve some symbols (such as the call to minuit), so it seems that they are not 100 % incompatible...
This is the beginning of the output:
ifort: Command line warning: ignoring unknown option '-fno-underscore'
../lib/libpacklib.a(minuit.o): In function `__g77_masterfun_minuit':
minuit.F:(.text+0x36): undefined reference to `s_wsfe'
minuit.F:(.text+0x3b): undefined reference to `e_wsfe'
minuit.F:(.text+0x6d): undefined reference to `s_wsfe'
minuit.F:(.text+0x72): undefined reference to `e_wsfe'
minuit.F:(.text+0x8e): undefined reference to `s_wsfe'
minuit.F:(.text+0xaa): undefined reference to `do_fio'
minuit.F:(.text+0xc6): undefined reference to `do_fio'
I'm using:
$ ifort -f77rtl fit1.f -L../lib -lmathlib -lkernlib -lpacklib
while with g77 was:
$ g77 -o fit1 fit1.f -L../lib -lmathlib -lpacklib -lkernlib
Is there a way to make it work (before recompiling the libraries)?
Thank you.
ifort is not link-compatible with g77. You'll need to recompile all the Fortran sources with ifort.
You should be able to link in C sources compiled by gcc.
