29382 Discussions
Migrating from Windows XP to Windows 7 (IVF 11.1)
blwiland
I currently have Intel Visual Fortran Professional v.11.1 installed on a computerrunning Windows XP. The development environmentisMicrosoft Visual Studio .NET 2003 (retail version of Visual C++.net Standard). I am getting a new computer with Windows 7 Professional, andneed tomigrate the Visual Fortran to this new computer.
Will Visual Fortran 11.1 and Visual Studio .NET 2003 install and run under Windows 7 without any problems orwill I need to upgrade something?
To migrate, do I first need to uninstall these from the existing computer to allow them to be installed on the new computer?
Thank you,
Bruce
DavidWhite
Valued Contributor II
Bruce,
Intel license allows Visual Fortan to be installed on more than one machine simultaneously- just need to license file / number to install.
Microsoft license for VS is for a single machine only. If you are to have two copies installed, you need two licensed copies. I think the upgrade to IVF 12 requires an upgrade to VS2010, so it may be time to consider upgrading VS with the change of machine. I'm still on XP, but have upgraded to VS2010 to keep up with IVF.
Regardins VS, note that unless you are doing mixed language compilation, you can use the bundled version of VS2010 with IVF on your new machine, without buying a separate MSVS license.
David
TimP
VS2003 isn't compatible with win7, although it should work in XPM, if your platform works with that, and you can accept the drawbacks. It would be preferable to run ifort outside XPM, using VS shell, or install a supported VS. I would think you should take the opportunity to use X64.
ifort 12.1 no longer supports VS2005. VS2008 or VS2010 (with service packs) are fine. If you wish to continue with 11.1, you should use 11.1.056 or later, but VS2010 will not be supported.
A table of Windows/VS/intel compiler compatibility was given on this forum earlier in the week.
anthonyrichards
New Contributor III
Tim(Intel),
I am concerned by your statement "ifort 12.1 no longer supports VS2005".
I have VS2005 and have Intel Visual Fortran Composer XE 2011 Update 6 Integration for Microsoft Visual Studio* 2005, 12.1.3514.2005, Copyright (C) 2002-2011 Intel Corporation installed and running OK.
What is the implication of your statement above for my IVF compiler?
Am I forced to either install VS>2005 or forego updating my IVF 12.1 compiler from now on?
Anthony
TimP
Well, the release notes for 12.1 indicate that VS2005 support was dropped. However, after a couple of hours of straightening out installation problems (not associated with VS2005), I find that ifort and icl 12.1.1 did integrate into VS2005 (with all service packs, including the Vista/Win7 supplement). A pure Fortran test seems to work perfectly well in this mode, but if I didn't want C/C++ I would simply install the VS2010 shell which comes with ifort. Mixed Fortran (ifort) and C (icl) built my test with no warnings, but shows a few annoying performance deficits in C code. Mixed ifort and C++ (icl) gave me fits attempting to build with .pdb (could be cockpit error), but still runs OK, again with a few performance deficits in the C++. Mixed ifort with MSVC seems to be OK.
I would take the statement of non-support to indicate that ifort and icl 12.1 under VS2005 are no longer tested, as they have to be tested with VS2008 and VS2010. I have no cause to complain about reduced icl performance and linking problems such as sorting out .pdb and having to specify (in my own peculiar setup) the specific VS2005 library/linker path. So it may be the icl 12.1 rather than the ifort which isn't optimum under VS2005.
From this, I suppose ifort 12.1 is worth a try under VS2005, particularly if you don't care about icl.
Generally speaking, I find better MSVC performance in VS2008 (with packs) or 2010 than 2005; I'm just saying that I didn't see unexpected deficits in MSVC 8 due to linking together with ifort 12.1.1.
blwiland
TimP,
Because of the cost of upgrading, I would prefer to continue to use 11. 1 for the present time, but my license only allows through 11.1 Update 4 (11.1.054). You indicate I need to use 11.1.056 or better. Did you mean 11.1.054?
If I understand correctly, to use IVF 11.1 natively in Windows 7 and x64, I would either have to use the VS shell which comes with IVF 11.1 or purchase the retail version of either VS2005 or VS2008 but not VS2010. I need to be able to use the dialog editor that comes with the retail version of VS, so I guess using the shellwill not be an option for me.
Alternately, it sounds like I can use my existing IVF 11.1 and VS 2003 if I run them under the XP Mode (which myWindows 7platform does have). Is this correct? You indicate that thereare drawbacks with using XP Mode.Are there additionaldrawbackswith XP Mode other than not being able to run IVF as 64-bit?
I could not locate the table of Windows/VS/intel compiler compatibility to which you referred. Can you give me a hint as to which thread itmight belocated in?
Thank you,
Bruce
TimP
This article was offered here on Tuesday. Looks like it could usefully be posted at the top of the forum.
You're right, according to that, 11.048 or later are suitable for running with Win7, and I got confused due to the linux and Windows version numbers being different.
If you're attempting XPM in order to use VS2003, of course the lack of X64 support is not an issue. I've seen comments about XPM having performance issues, although you would think it should at least match an older computer. I've used it very little, in part because it works on only one of my installations, so I'm no expert.
IanH
Quoting TimP (Intel)
Well, the release notes for 12.1 indicate that VS2005 support was dropped...
Are you sure? The release notes that I have for 12.1.1 indicate (under system requirements) that VS2005 is still supported. Another note later in the same section then suggests that support for VS2005 will be removed in a future major release.
TimP
OK, then VS2005 still works with ifort 12.1.1. I see the doc which says support for VS2003, Vista, and VS2005 will be removed in a future major release. Can't always believe what you've heard.
blwiland
Okay, thanks. I found the retail version of VS2008 for a reasonable price. So, based on your information, it sounds like Ican migrate to Windows 7 and run VS2008 + IVF 11.1.054 in the x64 environment. Thanks again, Bruce.
