29649 Discussions
Minimum installation Visual Studio 2008 Professional for Intel Visual Fortran
roy437
What is minimum installation Visual Studio 2008 Professional for Intel Visual Fortran ?
Software:
Visual Studio 2008 Professional Edition vers. 9.0.30729.1 SP with SP1
Microsoft .NET Framework vers. 3.5 SP1
Intel Visual Fortran Compiler Professional Edition 11.0.061 for Windows
Operating System: Windows 7 Ultimate
Hardware:
CPU: AMD Athlon XP 2500+, 1833 MHz
System Memory: 2 GB (PC3200 DDR SDRAM)
System type: 32-bit Operating System
Roy
Kevin_D_Intel
The minimum IVF version required for Windows 7 is 11.1 Update 2 (11.1.048), see link below for more discussion. Since you have 11.0 currently, probably best to go with 11.1 Update 5 (11.1.060)
Further discussion of 11.1 Update 2and Windows 7 at: http://software.intel.com/en-us/forums/showthread.php?t=68961
roy437
I want to install custom Visual Studio 2008 Professional. What modules should I install ?
Roy
You need Visual C++ from Visual Studio. Be sure to select the "x64 Compiler and Tools" component under Visual C++.
